05 rl sh-awd problem
I have searched the site and read most posts on here and can't find answer, my 05 rl had the sh-awd light come on and in mil display it says check sh-awd system! When I accelerate on loose gravel with vsa on only front wheels spin. Any help would be great
What I love most so far is that you are doing FWD drive burn outs when your AWD error light is on. :lol:
Have you taken it somewhere to have it looked at?
When was the last differential flush and refill?
Thanks for replies do u think a Honda dealer could tell me my nearest Acura dealer is 400 miles away? And I changed the oil just last night reading a post off here on it should be done.
Was the light on before you changed the oil?
I assume you mean differential fluid too, or did you mean engine oil?
Did you do both chambers of the rear diff?
What about the transfer case? Did you check that?
When mine went out, it just jerked like a hard shift and the lights came on.
If I remember correctly there was and AWD error light and a light that also said i was in FWD mode.
I called the dealer from the road side and they said to turn the key off and on to see if it resets the code, if not (which it didn't) they said it was safe to drive to the dealership.
I don't know that Honda vehicles have the SH-AWD system since the prelude... I would take it and have it looked at somewhere.
Ok thanks ya mine didn't jerk it came on just after start up and only the one light is on then message on screen.
I talked to dealer they said need to get code off and thought Honda dealer could get it for me
Even AutoZone can pull a code for you.
crapo85 (04-23-2012)
You may want to try the hard battery reset suggested by Acura. Disconnect the cables from the battery and short them together. With cables shorted, turn the ignition to position (II) and wait 10 seconds or so. Turn off, reconnect everything, and start it up.
I will try that after get code, I disconnected pos cable but did not touch together!
Thanks again
Ok guys first thanks for replies just thought would do update for u!!
So after going to several places to get code there was not one scanner that could pull a code. After talking to Acura dealer I took to local Honda service department they ran diagnostics and found a broken wire going to rear diff causing it too throw the lights on and into safety mode. So thank god it was only 100 bucks to fix not what bad rear end would of cost.
253RL (05-04-2012)
Lucky!!
SHAWD Light
I have an RDX, I bought it the first year the model came out. I think I have more miles than most at 210,000. The Shawd light came on at least 100,000 miles ago. I have taken it to two dealerships in California. They clearly have an issue that they don't know how to fix. They told me the turbo needed to be replaced, but it is clearly working. My son made a comment this weekend that I finally feel like could be the real reason for the light. The all wheel drive is not working. He said it is the difference between having the car pushed from behind or pulled from the front. We had new tires put on not long ago. He noticed the back tires are still brand new and the front tires are bald. He said there is a light panel that shows how the power is pulling, why is this so difficult to diagnosis:wish. I have an appointment on Thursday, we will see if they can figure it out now!
I would say your front tires are bald because your son is doing massive front wheel turbo burnouts because your sh-awd light has been on for the last 100k miles. Get them to give you the code for it.
I don't know how an Acura dealer could not diagnose this problem. Take it to a different dealership. BTW, be prepared to pay. Servicing the AWD system is never cheap.
Just an FYI for everybody, if your SH-AWD light is on your car is now FWD. This is a fail-safe that has been intentionally built into Honda/Acura's torque vectoring systems since the Prelude Type-SH way back in 1997. It is there to keep the car from damaging expensive parts. I owned a 98 Prelude Type-SH before my RL. Any time a check engine light came on it was accompanied by a big yellow ATTS light letting you know that the $3k ATTS unit has been disabled to avoid any damage.
100k mi later...
SidhuSaaB
05-30-2020 12:40 AM
