05 RL question about oil
Old Aug 6, 2008 | 05:04 PM
dhag8's Avatar
05 Acura RL
I just got my RL last month and have no clue what to do about changing the oil. My BMW has a alert system that notifies my if I need a change. Does the RL have this? How often does it need to be changed? Also, what kind of oil do you guys use and where should I go to change it? Sorry about all the questions but I don't want to have problems because of negligence and it only has 18K miles.
Any info in much appreciated.
Old Aug 6, 2008 | 06:56 PM
geronimomoe's Avatar
I don't have an RL. Came close to buying one and did a lot of research on it. The car has a MID, which tells you when to bring it in for service.
However, I'd say that a 6 month/7500 mile interval is safe for oil changes. I've read conflicting stories about the extended OCI on BMW's and the engine's sludging up. So I'd go conservative.
I believe the RL takes 5w-20. I'd do it myself, with synthetic. I personally use Mobil1 in my cars. Amsoil, Redline, Penzoil Platinum, are also good synthetics. If you're not a DIY person, bring it to a dealer.
Old Aug 6, 2008 | 09:29 PM
fstshrk's Avatar
Yes
Press the SEL/RESET button in the middle on the right hand side of the steering wheel hub and it should scroll until it shows OIL LIFE and a percentage value.
5W20 synthetic.
Acura Dealer
Old Aug 7, 2008 | 04:04 PM
dhag8's Avatar
05 Acura RL
mine says the oil is at 20%. what does that mean? should i only take it to the dealership for oil service or can i take it anywhere?
Old Aug 7, 2008 | 09:14 PM
fstshrk's Avatar
It will tell you when it is due. It is not due yet.
Old Aug 7, 2008 | 09:50 PM
Chas2's Avatar
At 15% you will start getting annoying notices to think about changing your oil. You can take it anywhere. If you take it to other than an Acura dealer, you may have to do the reset yourself. It is a few menu steps on the MID (Multi Information Display) and is well explained in the manual, with pictures...
Old Aug 8, 2008 | 10:31 PM
The 20% means the MID thinks there is 20% of the life left in the oil. Since the mileage of the car is so low (18K miles in roughly 3 years), assuming you don't know when the oil was changed last, time wise, I'd change the oil now. It doesn't hurt.
As I posted earlier, if you're not a DIY'er, bring it to a dealer, which other folks have said too. The cost differential is insignificant IMHO between the dealer and "anywhere"..
BoricuaTL
Apr 8, 2016 01:08 PM
IIDXholic
Oct 8, 2015 07:53 AM
atsx1313
Sep 22, 2015 09:04 PM
VolkingTL
Sep 16, 2015 09:10 PM
datadr
Sep 12, 2015 09:12 PM
