'05 AC Transistor?
Old Jan 23, 2018 | 07:02 PM
swake457's Avatar
'05 AC Transistor?
Hey guys, I just recently had the cabin blower motor quit on me. All other AC/heater components checked out, just the inside blower motor wouldn't turn on no matter what speed. I had a local shop that I've been using for years diagnose and replace a "transistor". Well, it just konked out again on my drive home. Same symptoms. What I would like to know is where is this 'transitor' located and does anyone have tips to troubleshoot? I suppose it's possible to have a failed replacement part, but I'm more concerned something else is causing it to fail. Either way, I'd like to pull it and at least check the unit to see if it's still good or not with a multimeter. From the photos I've managed to find, this looks like it might be located somewhere directly adjacent to the blower motor itself. I found this part on amazon that looks similar but I don't know the exact part number. I know sometimes 05 MDX and Pilot parts are compatible.
Amazon Amazon
Saw a couple other threads from about 8 years ago. Pretty sure this isn't the compressor or the stator.
Thanks in advance!
Old Jan 26, 2018 | 10:21 PM
projektvertx's Avatar
Do you mean the resistor module for the blower motor? Don't those usually manifest as the blower either not working, or working at max speed only?
Old Jan 27, 2018 | 12:09 PM
swake457's Avatar
Yeah, same part. I thought the same, but when I asked my local tech that he said it really depends on the failure and sometimes the model car. These 05 RL’s can have the blower motor resistor basically burn out and the blower won’t run at all. It won’t show on any built in diags. Only a multimeter test can definitely confirm it’s fried,if not visually evident. I’d like to buy this part though, maybe as a spare.
afbryant
1G TL (1996-1998)
Mar 9, 2020 07:14 PM
DimondD
Nov 30, 2015 04:02 PM
dannheisser
Feb 26, 2010 06:39 AM
milyundlrsmile
Dec 18, 2009 10:25 PM
