Wheel compatibility question
Old Sep 23, 2020 | 08:06 PM
VoltRd's Avatar
Thinking about purchasing a set of ILX A-SPEC wheels for my 2016 rdx. Will they fit no problem? Size and offset are the same as my oem wheels, 18x7.5 +45 offset. Making sure before I pull the trigger. Thanks
Old Sep 23, 2020 | 10:06 PM
hub bore is the same and lug nut pattern is the same. will fit no problem.
obviously tire size is different, but looks like you're buying brand new ilx wheels, which means you would either buy brand new tires or swap your tires over.
Old Sep 24, 2020 | 09:28 AM
VoltRd's Avatar
yes, will just be swapping tires over. Thank you
Old Sep 24, 2020 | 11:08 AM
pretty neat little upgrade!
Be sure to post pics of the new wheels on your RDX!!!
Old Sep 24, 2020 | 03:40 PM
Tech's Avatar
Originally Posted by VoltRd
18x7.5 +45 offset.
Exact same size and offset as the original wheels that came on my RDX Advanced/Elite. Center bore is 64.1 mm.
odehboy
May 31, 2010 05:37 AM
aSPECtL06
Jun 30, 2007 08:10 PM
Mungkee888
May 28, 2003 10:14 AM
kcroberge
Apr 13, 2002 11:33 AM
