Do you put TPMS sensors on winter tires?
I would get a set of programmable ones. You can copy the ID's from your original set and clone them to the winter set of tires. There will be no re-programming the TPMS sensors in the car every season change, just swap them out in winter and spring.
A cheap programmer is the Autel TPMS pad to read and program sensors. Use the Autel MX sensor I think you will need the 315MHZ one but i am not sure,
The TPMS pad is not designed to read sensors directly from sensor mounted in tire but I have done this on all Honda's and Acura's with no issues.
JustinZ
09-09-2009 07:45 AM
disco1999
09-14-2008 11:11 AM
slimmyjimmy
05-18-2006 12:02 PM
