2016 RDX wheels, different offset?
Old 10-08-2015, 11:24 PM
Nuclear's Avatar
I have a great deal on a set of KIA 18" rims. Here are the specs.
The rims are from a Kia Sorento. They are 7.5Jx18 ET49, which means an offset of 49mm with a width of 7.5 inches and a diameter of 18 inches. The bolt patter is 5 x 114.3 mm. The centre bore is 67.1 mm
The bolt pattern should be fine but I'm worried about the 49mm offset and don't know much about centre bore. Can anyone chime in? Thanks.
Old 10-09-2015, 09:40 AM
andysinnh's Avatar
Honda/Acura center bores are typically 64.1mm, so you'd need a very thin hubcentric ring to make sure the wheels seat true on the hub. Also, the offset for the 7.5" wheels on these cars is still at +45mm, so you'd be ever-so-slightly sending the wheel inward - probably not enough to impact things, but you might get a slightly different feel when turning since you'd have slightly different geometry.
As an FYI, the CR-V wheels (which fit the RDX are typically 6.5" wide, and as such the offset is +50mm - so that loss of an inch in wheel width is compensated by slightly moving it inward...
good luck - andy
Old 10-12-2015, 07:49 PM
hand-filer's Avatar
Are you wanting them for winter tires?
I can cut you a good deal on these:
Old 10-12-2015, 08:32 PM
Nuclear's Avatar
I'm interested. Those look crome though. Also what are the specs?
Old 10-13-2015, 09:43 AM
2021 RDX A SPEC
Acura604's Avatar
**handflier, if nuclear doesn't take them.. PM me... I'm out of Vancouver, BC and am interested.
NUCLEAR: those are ebony chrome 19" RDX wheels from 1st gen.
thanks.
Old 10-13-2015, 11:58 AM
hand-filer's Avatar
PM's sent.
thanks.
RedRyder
11-02-2015 11:03 AM
polish_pat
15
10-19-2015 04:46 PM
seoulTL
10-12-2015 02:27 PM
eaf
10-07-2015 11:50 PM
c1souk
09-28-2015 11:20 AM
Quick Reply: 2016 RDX wheels, different offset?
