Volume is much lower with Bluetooth vs radio
Old Jan 15, 2025 | 09:43 PM
Silver17RDX's Avatar
8th Gear
When I Bluetooth music in from my iPhone the volume is much lower than the FM radio or other sources. I’d say full volume (40) is about as loud as 25 on FM. I couldn’t find any setting to adjust either.
Has anyone had this issue and found a solution?
Old Jan 15, 2025 | 10:22 PM
altair47's Avatar
Sometimes there is a problem that some Acura bluetooth modules do not want to work correctly with phones with a newer version of bluetooth. The problem is solved by buying modules with a newer firmware. But first I would try to do a full system reset and re-pair the devices.
Old Jan 16, 2025 | 10:00 AM
Alex Medeiros's Avatar
alexmed2002
Additionally, make sure the settings are correct in the app you're using to play the music. A lot of them have ways of being able to lower the overall volume to sound very level.
Old Jan 18, 2025 | 02:02 PM
dvd2012tl's Avatar
The volume coming from my car bluetoooth varies with the valume setting.on my iPhone. Due you have the volume turned up alll the way on your iPhone?
Old Jan 19, 2025 | 10:55 AM
8th Gear
That worked! Thanks so much for this comment. I had tried the volume on the phone but if I hold the volume up button for a few seconds it adjusted it perfectly. On my other cars that use CarPlay or Bluetooth, volume is delegated to the car volume control and the phone volume doesn’t do anything. This system works different. Thanks again!
RobRDX
Dec 20, 2017 10:23 AM
RT Fiore
Nov 9, 2017 04:51 PM
Milord1814
May 17, 2017 03:27 PM
Joe Las Vegas
Aug 22, 2013 06:01 PM
MrOtocinclus
21
May 17, 2012 02:38 PM
