Transmission message
Old Jul 5, 2021 | 11:41 AM
Kool Pops's Avatar
i have an engine light on and transmission message on display for a 2015 RDX. Any ideas please? Thank you
Old Jul 5, 2021 | 06:40 PM
Ron A's Avatar
Administrator
A belated welcome to the forums. The forum where you originally posted, the AcuraZine User Help, Support & Suggestions Area , is meant for problems, comments, and suggestions for the website itself, so I moved your thread to the car specific forum applicable to your vehicle.
This was explained in the sticky thread at the top of that forum, or click here if you can't find it, which will explain why you shouldn't have posted your thread there.
Old Jul 5, 2021 | 07:01 PM
gotta find out what the check engine light is for..gotta use an OBDII reader to find out... once you know the exact code, then we will have better ideas...
also, what is the exact message on the display???
Old Jul 5, 2021 | 08:16 PM
Kool Pops's Avatar
thank you
Old Jul 6, 2021 | 12:28 AM
egads's Avatar
How many miles on the vehicle? What is the message? Ever changed the fluid? What model? Front wheel drive or All wheel drive?
All Honda/Acura vehicles since forever have required regular trans service. That would be a service required number 3. Service letters and numbers
are set once the oil life reaches 15%. Service required and a check engine light are different. Check engine lights are a little picture of an engine. When have
One of those, a code will be set that can be read by a code reader. Some codes can only be read by a manufacturer's reader. Many auto parts stores will read codes
for you. Or, with a deposit, allow you to borrow one. The code reader connector is directly under the steering wheel with a universal connectors since about 1996.
OBD stands for onboard diagnostics.
MastahP
New Member Introductions
Jan 22, 2020 03:19 AM
Lou_lou
Jun 25, 2019 08:43 AM
NOcasio7
Mar 20, 2017 08:27 AM
