Problem Fueling Up - Pump Clicks Too Early
Old Sep 10, 2012 | 08:37 PM
mykey06's Avatar
Hey guys... Not sure if anyone has also experienced what I am experiencing. It happened me 3 times already. At the pump when fueling up my RDX (close to empty), the pump nozzle click to stop after 5-7 gallons of fill up. Even after I try to keep fueling up, it will just keep on clicking and stopping after 3-5 seconds. I would have to keep doing that until I know I am close to full tank.
This has happened to me several times at different gas stations using different pumps.
Old Sep 10, 2012 | 09:06 PM
HEAVY_RL's Avatar
are you pushing the pump nozzle all the way in so there is a seal
Old Sep 11, 2012 | 10:13 AM
mykey06's Avatar
Yes. I tried that as well.
Old Sep 11, 2012 | 11:15 AM
GRDX's Avatar
Some stations will crank up the volume output on the pumps to get the customers in and out faster. Some cars fuel tanks cannot accept the gas so fast and the pump will shut off prematurely. If you set the fill speed one notch slower on the handle that should take care of your problem. Some pump handles don't have the little ratchet thing to set the speed and you must hold on to the handle while it pumps. If that is the case just don't hold the trigger fully depressed.
Old Sep 11, 2012 | 12:00 PM
mykey06's Avatar
Good to know. Thanks GRDX!
Old Nov 17, 2012 | 08:21 AM
ottoman101's Avatar
It could also be the nozzle on the pump. It's it's old or defective it may click to early, or not at all (causing gas to spill everywhere). The latter happened to me at my first fill up with the new car.
Old Nov 17, 2012 | 09:31 AM
CoachRick's Avatar
Two of our Volvo C70s were a pain to fill. I found that backing the nozzle out just a bit and turning the handle to about 8 o'clock was the only way to fill the tank without multiple shut-offs. Thankfully, our newest C70 doesn't have this problem and I've experienced a quick shut-off only once in the RDX.
pstomps
Feb 20, 2017 03:29 AM
Gary Matthews
2G CL Problems & Fixes
Sep 11, 2015 01:21 PM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
NSolace
Sep 3, 2015 08:14 PM
