Maintenance Reminders- problem
Old Aug 10, 2017 | 09:57 AM
Tamika Stewart's Avatar
Hi I have a 2015 RDX that I purchased in May with 22k miles. I now have 29k miles and the maintenance reminder came on. Problem is I have and A3 and and A13 with a wrench. How is it possible that I need a transmission service at 29k miles? Is this typical? What should I say to the dealer tomorrow? I'm asking now because I have learned that I really need to know about my car before I get tricked, scammed by the dealer. Does this also mean that I'm going to have transmission problems with this car? I'm worried...
Old Aug 10, 2017 | 10:09 AM
A-oil change
1- tire rotation
3 - transmission fluid service
so, the car is asking you to get these services performed...
3 - is a simple transmission drain and fill.
Old Nov 30, 2017 | 10:20 AM
tegraphile's Avatar
It seems that the 30K transmission drain/fill is not out of the ordinary for this model, although I've usually seen 50-75K for most other vehicles.
I recommend you shop around dealerships and see if there are any deals. I just dealt with a transmission/torque converter issue which suggests a ATF replacement, so it might be helpful for your car to complete the service.
Old Nov 30, 2017 | 10:35 AM
mrgold35's Avatar
mrgold35
Transmission service at 30K was the norm for my TSX, RDX, and MDX. After that, it might not show up again until 60K-120k mark (or longer) depending on driving conditions. AT service depends on the dealership because they can do a 1X drain and refill for around $100 or the suggested 3X drain/refill for around 3X more $$$. I wouldn't take to a local repair shop for transmission service unless you supply the Acura/Honda AT fluid. Acura ATs are picky on the type of fluid to use or they could fail in a very short time (learned the hard way on a 97 Accord 4AT back in the day with a Jiffy Lube AT special).
Sticking to the M.I.D. maint schedule is a good way to get 200,000 miles from the powertrain. At the same time, you don't have to service at the dealership if you like DYI or find a good local shop.
