Issues with 2013 Acura RDX
Old Sep 27, 2019 | 11:50 AM
justin stoufflet's Avatar
The lower bolt was behind my tensioner pulley, and I had to wedge a 3/4 wrench between the frame and the ratchet I had on the tensioner pulley. Can’t get to the lower nuts on the fan shroud without removing the undercarriage cover...so I am going to try to pull it out through the passenger side once I’ve pulled the radiator overflow bottle. Afraid to remove all of the snapping tabs that hold the undercarriage cover because about half of them will probably break when I try to put them back in...The alternator was jammed in at the lower bolt bracket. I had to work back and forth a lot to get it out. Its going to be hell trying to get the new one in. Any tips?
carloverthepond
1G RDX Tires, Wheels & Suspension
Nov 18, 2015 12:35 PM
Skunkworkz
1G RL (1996-2004)
Mar 3, 2015 05:57 PM
RDXfreak
Nov 25, 2013 10:40 AM
Sportschicfla
Sep 19, 2013 09:28 AM
hawkeye252
May 8, 2012 01:32 PM
