hesitating while changing gears
Old Sep 13, 2022 | 01:55 PM
tinmaner's Avatar
2018 RDX tech
Mileage - 23k miles
Recently started hesitating / jerking slightly while shifting gears .. i did complain about it while getting the service done and the dealer suggested getting the Tans and Transmission fluid changed to resolve the issue.
any one else had this issue ? is it really about the Trans and transmission fluid ? i had a mini cooper before and the mileage for transmission fluid for that car is around 50k miles ..
Old Sep 13, 2022 | 04:29 PM
Poolman's Avatar
Our RDX transmissions are supposed to have the fluid changed every 30k miles. If that makes the fix, which I doubt, then you might need to have to take a look at possibly one of the pressure sensors.
Old Sep 14, 2022 | 11:04 AM
dtownfb's Avatar
The maintenance minder determines when the transmission fluid needs to be changed. Like Poolman said, it normally triggers somewhere around 30k miles, depending on your driving. You have so few miles on your 2018 that changing the transmission fluid now is not a bad idea. Also ask if there is a transmission software update available.
If you bought it used, you may want to disconnect the battery so the transmission can adapt to your driving. I had to do that after I purchased my 2017.
Good luck.
Old Sep 19, 2022 | 12:45 PM
tinmaner's Avatar
Good luck.
no i got the vehicle new ..
i did ask about software update and the dealer said they cant do it unless the MM asks for it ..
ill check about transmission software update
dpw-ct
Dec 15, 2023 01:13 PM
Martin Cander
2G RDX Problems & Fixes
Mar 4, 2021 05:24 PM
wbarnum
Dec 29, 2018 11:09 AM
komet
Jul 29, 2012 02:47 PM
