Climate control
Old Mar 8, 2013 | 01:24 PM
qksilver1's Avatar
Climate control
In our 2013 rdx tech package when the climate control is in auto mode and heat required, the warm air only seems to be coming out of the side vents and nothing out of the centre dash vents. When the temp calls for cooling then the cool air is coming from the dash center vents as well as the side vents. In manual mode when you select dash vents the warm air comes out of the center dash vents no prolem but for some reason not when it is in auto mode calling for heat. The car heats up no problem but as I said just doesn't have have warm air coming out of the center vents. Just wondering if this is normal or anyone else has found this?
Old Mar 8, 2013 | 09:33 PM
C0rrion's Avatar
It's normal... having the heat come from the center top vents does not heat the car effectively. You should also notice the heat coming from the bottom vents (near your feet).
Old Mar 8, 2013 | 10:35 PM
geocord's Avatar
Normal. That's the way other cars with auto climate control work too. AC comes out the dash vents. Heat comes out the floor vents(heat rises) and the side dash vents to keep the side windows from fogging up.
Old Mar 9, 2013 | 06:09 AM
qksilver1's Avatar
Okay thanks. Appreciate the information. Glad that its normal and working properly.
knight rider
Mar 4, 2016 08:59 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
adreano17
Sep 29, 2015 08:48 AM
CWOVette
1/2G MDX (2001-2013)
Sep 27, 2015 02:29 AM
Brandle34
Sep 23, 2015 07:20 PM
