MDX roof rails for my RDX
I prefer the low profile mdx roof-rails to the higher profile rdx (2016) / can the mdx rails fit my rdx ??
Originally Posted by Ed206
(Post 16075846)
+1
(Post 16075846)
Has anyone installed roof tracks or direct mounts, bypassing Acura rails altogether? Yakima and Thule make both, but I haven't seen an RDX install. JC |
Originally Posted by JCRDX
(Post 16092515)
I'm researching a roof rack setup too, and don't care for the stock RDX rails. If you get some confirmation on the more contemporary MDX rails working, please report back!
Has anyone installed roof tracks or direct mounts, bypassing Acura rails altogether? Yakima and Thule make both, but I haven't seen an RDX install. JC In order to get Thule bars to work for the rdx, you need three things: thule rapid traverse footpack thule aeroblade bars (53" is recommended but you can go longer) thule fit kit - KIT1724 the best thing about these bars is that it can be easily removed if needed and thrown onto a different car, as long as you have the proper fit kit for the car you're installing them on https://cimg3.ibsrv.net/gimg/acurazi...9088144a62.jpgNot the best pic but hopefully it gives you an idea |
Gutter mount vs fixed rails
Originally Posted by johnnyytruong
(Post 16092602)
when I was looking into buying a roof rack, I went back and fourth on either getting factory rails and crossbars or going with Thule bars. Cost was probably the biggest factor for me when deciding so I ended up with the Thule bars.
In order to get Thule bars to work for the rdx, you need three things: thule rapid traverse footpack thule aeroblade bars (53" is recommended but you can go longer) thule fit kit - KIT1724 the best thing about these bars is that it can be easily removed if needed and thrown onto a different car, as long as you have the proper fit kit for the car you're installing them on Not the best pic but hopefully it gives you an idea I would prefer permanent rails or fixed mounts and nothing that clamps inside the door opening. (I had a bad experience with gutter mounts previously.) |
(Post 16094284)
That looks pretty good! What is the maximum spread (distance between crossbars)?
I would prefer permanent rails or fixed mounts and nothing that clamps inside the door opening. (I had a bad experience with gutter mounts previously.) they recently made the black rails and crossbars available to purchase separately (in Canada) and not part of the accessory package along with the wheels and running boards. Definitely liking the look.. |
