Best Ventvisors for RDX
Old Jun 22, 2022 | 10:25 AM
jallenhayslett's Avatar
Can’t seem to figure out the best search terms to find previous posts.
Which vent visor company is recommended for the RDX? Seems like there’s a million of them.
Old Jun 23, 2022 | 05:19 AM
Kelsen's Avatar
Search works well, but not very intuitively using this interface. What IO have found gets results is:
1. In the search box, rather than typing your search term in the right-hand side (where it says 'search threads', click on the left side, where it says Threads.
2. Choose 'Advanced' from the drop down menu
3. On the Advanced screen, type in your keyword term, in this case, say, visor.
4. go down to the box on the bottom right that says Search in forum(s), and select the forum you want to search, in this case, Second Generation RDX (2014 - 2018)
5. Also select the box at the bottom of that box that says Also search in child forums
6. Don't select or change anything else (although you may want to 'Save Search Preferences' at the very bottom)
7. Click on 'Search now', just above the very bottom
That should find what you are searching for, and highlight your search word in each of the resulting threads (you have to select each thread to see it; your search term will not necessarily be visible on the search results screen, but will be highlighted in red within the resulting threads.
RFT!!!
Dave Kelsen
People will accept your ideas much more readily if you tell them that Benjamin Franklin said it first.
anoop
3G RDX (2019+)
Jan 10, 2022 07:16 PM
Tyler Jongriff
1G RDX (2007-2012)
Sep 22, 2018 10:07 PM
rockyboy
3G RDX (2019+)
Aug 7, 2018 10:26 PM
rockyboy
Nov 13, 2015 09:00 AM
