2013-2015 RDX rear signal LED conversion - success / no hyper flashing
Old 11-26-2015 | 12:46 AM
Acura604's Avatar
2021 RDX A SPEC
As some of you know from this thread :
https://acurazine.com/forums/second-...equest-937048/
I found the Phillips vision LED to work perfectly for our tails...so why not our rear signals also? After all they are 7443.... So I decided to test them out. And YES! Works great - no hyper flashing or resistor crap. and of course, no errors on dash!!!
Videos : (better quality videos coming day/night)
Philips LED driver side , regular halogen passenger side
Both sides LED
Old 11-26-2015 | 07:38 AM
Mr_MDX's Avatar
Thanks! I very much appreciate the side by side video too.
Old 11-26-2015 | 10:32 AM
Acura604's Avatar
2021 RDX A SPEC
sorry to report back....hyper flashing started..... Damn....back to the drawing board!!!
Old 11-26-2015 | 05:50 PM
carbonTSEX's Avatar
The Original Shawdy
Gotta install resistors to fix it.
Old 08-25-2016 | 11:34 PM
BooBooKaki's Avatar
9th Gear
Wish the 2017 RDX's had LED rear turn signals like the front signals. I thought about swapping to LED turn signals but it was too much work to gain access to the bulb.
Old 10-03-2016 | 06:48 PM
chickdr's Avatar
I just came here to look for a DIY to access the rear turn signals. I want to put chrome amber bulbs to hide the orange but don't see how you would access the bulbs. Why would they do that when incandescent bulbs will eventually burn out? I have never seen a car with no access to bulbs like this. You can easily get to the license plate and reverse lights....
Old 10-03-2016 | 07:13 PM
chickdr's Avatar
Ok just figured it out. There is a small plastic panel just outside the rear door seal which pops off and two philips head screws come out then the light pops off. Very easy to do once you realize how it is attached.
Old 11-19-2016 | 06:16 AM
nitrateppg's Avatar
5th Gear
I used the Zevo with load resistors. Minor PITA, but it worked out great. The fronts are a completely different story. I can't sufficiently access the wiring and have no idea how to remove the headlamp housing (which is really the only way I can get it done).
Old 08-29-2017 | 10:09 PM
acuraspd's Avatar
3rd Gear
Has anyone tried to add a LED third brake light from a 16+ RDX to a 13-15 RDX? The housing size looks the same.
Also, What brand of LED are you using for License plate and brake light?
Old 08-30-2017 | 09:58 AM
Brown13's Avatar
I used the Philips 7443 in My brake lights and the radio hisses when the brake is applied.I e-mailed Philips to tell Them about the problem.They said yes,that can happen.So the Philips lamps sit in My basement.I bought led's from ebay that work fine.
Old 08-30-2017 | 10:12 AM
Diode Dynamics's Avatar
Former Sponsor
Here's a helpful video explaining resistors, how to install them, etc etc
Most vehicles will require resistors when replacing incandescent bulbs with LEDs in turn signal locations. There are a few rare exceptions, but all Acura vehicles will hyperflash without them installed.
Thanks!
Nick C.
Old 08-30-2017 | 10:49 AM
acuraspd's Avatar
3rd Gear
That would be annoying haha. So I am going to install LED in my brake lights and then also do the LED with resistor (thanks Diode). But, I have been looking at the 16+ RDX and the high mount brake light is a LED strip and looks similar in size to the 13-15 RDX. So I may just order one from Acura and try to swap it out.
Old 10-11-2021 | 12:17 PM
Mr Twisty's Avatar
Curious to see if you ever ordered the third high LED brake light and if it is compatible
Old 10-16-2022 | 03:52 AM
Mr Twisty's Avatar
So stupid question for our 2Gen RDX folks, which colored wire do we need to wire the resistors too?
I have combed over these forums for over two years and never found that info.
Old 10-16-2022 | 02:57 PM
altair47's Avatar
This is a load resistor, it is installed in the circuit to increase the load, and not lower the voltage, so it is placed in parallel.
Old 10-16-2022 | 03:33 PM
Mr Twisty's Avatar
Specifically what I was looking for was the colors of the wires it needs attached too. I understand the principle and had them installed on my 12 Pilot.
Old 10-16-2022 | 11:23 PM
altair47's Avatar
If the Mitchell diagram is correct, then the resistor should be set like this.
Old 10-17-2022 | 12:06 AM
Mr Twisty's Avatar
Unfortunately the one I need is not for the rear lights, it's for the front turn signals (colored wires or labeled wires would of even more help). I appreciate everyone's input.
Dragon27
ZDX
05-12-2015 08:17 PM
DevtypeS
3G TL Photograph Gallery
02-20-2012 08:09 PM
Aretardedorange
02-19-2012 04:09 PM
NJ Vike
1G RDX Problems & Fixes
07-02-2009 06:14 PM
V.NaK
1G TL (1996-1998)
06-01-2003 12:30 AM
