Fuse blown
Fuse blown
Last night I returned home shortly after 9 pm. I pulled into my garage and pressed the button to turn my car off. The engine turned off, but everything went off with it; headlights, interior lights, door lock/unlock, etc.. Before I go out there in the cold (it is a separate, unheated garage and I live in Fargo, ND), can any of you electrical types tell me what fuse or fuses are likely to have blown when I pressed the "Start" button to turn the car off? I do have a layout of the fuseboxes, but I see several that might be the culprit. Also, has anyone seen this behavior before? My (2014 Tech) car has 165K miles (50K of them are mine), and I have never seen anything like this.
Thanks.
RFT!!!
Dave Kelsen
Police officer: there s a dead body in your basement.
Schrodinger, sighing: Well, there is now.
Thanks.
RFT!!!
Dave Kelsen
Interestingly, when I went out to my car yesterday to begin diagnosing this problem, it was still there when I opened the door -- no lights came on in the interior, and the door could not be locked with the door switch or the key fob. But I sat down and pressed the brake and pushed the "Start" button anyway. And just like that, everything worked. It reset some of my electronics, and asked for a code (which the screen told me could be 'bypassed' by holding the power button of the entertainment system down. But I had not lost my programmed radio stations. It reset my current tankful's miles and mpg information (as if I had refilled the tank). But everything worked, and I did not have to replace any fuses. Very odd.
RFT!!!
Dave Kelsen
Knowing others is intelligence; knowing yourself is true wisdom. Mastering others is strength; mastering yourself is true power. If you realize that you have enough, you are truly rich. -- Tao Te Ching
RFT!!!
Dave Kelsen
Good thought, Alex, but it is only about 18 months old, and has never hesitated to start the car, even in North Dakota cold.
RFT!!!
Dave Kelsen
Attila the Nun - a simple girl pledged to a life of violence.
RFT!!!
Dave Kelsen
Ah! That is a thing I will look at; whatever it was, it was related to me pushing the "Start" button; perhaps with my glove on, I accidently pushed it twice quickly, not feeling it depress all the way the first time. And when I tried again the next morning, the power was still absent; neither the interior lights (as well as the headlights) did not come on when I opened the door, but everything (lights, starter, etc., worked when I pushed the "Start" button. So something like a sensor that might have electrically reset is a possibility!
RFT!!!
Dave Kelsen
"Fix reason firmly in her seat, and call to her tribunal every fact, every opinion. Question with boldness even the existence of a god; because, if there be one, he must more approve of the homage of reason, than that of blindfolded fear." -- Thomas Jefferson
RFT!!!
Dave Kelsen
images
Mar 24, 2010 12:58 PM
