Antenna Assembly Bracket location
Old Feb 23, 2017 | 04:37 AM
Damillej's Avatar
Hi everyone,
Change the front end wire harness on my 2016 RDX. The mechanic installed the new harness but forgot to mount the Antenna Assembly brackets 38388-TX4-A00 #7 & 38388-TX4-A10 #8 and the sensors 38387-TZ5-A01 #6 (see pic and link attached). He is no longer around for me to ask what was the location. Can anyone help me with the exact location to mount these brackets? thanks in advance.
Old Feb 23, 2017 | 07:38 AM
rosen39's Avatar
From the link below, it appears parts #6 are antennas located near each wheel. They may be there to pick up the TPMS signals from each wheel. The parts #7 & #8 may be inside the wheel housings.
OEM Acura RDX 5-DOOR 2016 SMART UNIT (2) parts
Old Feb 23, 2017 | 08:08 AM
rosen39's Avatar
Better diagram attached. Drive it up on some ramps and see if you can locate where the mounting brackets go. May be attached to the frame.
File Type: pdf
