VCM Algorithm
Old Dec 23, 2012 | 08:38 AM
pilozm's Avatar
VCM Algorithm
Does anyone know where I can find the algorithm for the Variable Cylinder Management (VCM II) system? i would like to know the details on when (what conditions) the engines mgmt decides to run on all cylinders or shut off 1 cylinder or shutdown 3 cylinders. i expect that this is not a secret, as I would simply like to know how a product's critical system, functions.
TIA
Old Dec 23, 2012 | 07:20 PM
rdxm's Avatar
This is the best explanation I found so far:
http://world.honda.com/automobile-technology/VCM/
Old Dec 25, 2012 | 06:54 AM
pilozm's Avatar
Thanks. That link is good info on what VCM is and how it saves fuel.
Not sure why it's so hard to find the information that i am looking for.
Old Dec 25, 2012 | 11:44 AM
boogerdood's Avatar
How about at idle?
Old Dec 25, 2012 | 03:26 PM
C0rrion's Avatar
That would be the same as "braking to decelerate", no fuel is given to the engine.
Old Dec 26, 2012 | 10:15 AM
musty hustla's Avatar
basically you only get all 6 cylinders if you're at WOT?
Old Dec 26, 2012 | 06:00 PM
boogerdood's Avatar
No, anything more than cruising will kick in 4, 5 or 6 cylinders. ID imagine there are only a few light throttle situations where only 3 cylinders are firing.
Old Dec 27, 2012 | 10:58 AM
ipribadi's Avatar
Guys,
VCM operates in 3 or 4 cyl modes, there is no 5 cyl mode.
Either sealing off all 3 cyl in one bank (leaving the other bank of 3 active) or 1 cyl in each bank (leaving 4 active).
During hwy cruise I noticed VCM can steadily remain on at around 70mph even with slight uphills. It's still on at 75mph but any slight inclination and it turns off.
I really don't know where 4 cyl mode comes in.
For idle; 3 cyl mode may cause rough idling so who knows.
I really hate how on the RDX there is no VCM indicator in any of the screens.
Old Dec 27, 2012 | 11:38 AM
AmberB's Avatar
I'm a dude you reprobates
Doesn't the instant mpg bar graph sort of act as one? When it goes above 40 mpg it's either in 3 cylinder mode. If you are off throttle and coasting you are in no cylinder mode. When it drops to 20 mpg or less it's in 6 cylinder mode.
Old Dec 28, 2012 | 01:44 PM
ipribadi's Avatar
Haha .. that is true.
But it's hard to tell, did the mpg just drop because of the downshift (higher RPM), deeper accelerator or just because VCM turned off?
I'm not hoping for a Honda like blue green light sceme or a special dash light, just a simple indicator on the MFD (while in MPG mode) would suffice.
Old Dec 29, 2012 | 07:59 AM
pilozm's Avatar
So, in the end, i guess there is no definitive document or web page by Acura, that shows the exact condition when cylinder deactivation happens on the RDX.
Perhaps the answer is too technical and could only be understood by mechanical engineers, or perhaps the average RDX owner does not really care how the VCM in their car works.
Guys,
Feb 25, 2020 09:57 AM
joflewbyu2
Oct 8, 2015 11:16 AM
Sep 17, 2015 10:16 AM
kuzdu
Sep 10, 2015 08:42 PM
