Usb Flash Drive Folders
Old 06-07-2013 | 09:28 AM
DennisLeo's Avatar
8th Gear
I loaded new folders onto my USB flash drive to play in my car and now the navi is not seeing the new folders. Is there a reason why? Should I try to refresh the folder?
Old 06-08-2013 | 09:44 AM
DennisLeo's Avatar
8th Gear
Bump anyone know why I cannot see the new folders in my car, but can see them on my comp.
Old 06-08-2013 | 10:33 AM
weather's Avatar
Not sure...I use a USB stick in my RDX and never had any problem seeing them. Now you will find many annoyance with the USB and its folder functionality but I will not ruin your disappointment....You can see my gripe in the problem section.
dc5k20z1's Avatar
Dont put them in folders
Old 06-08-2013 | 10:37 AM
weather's Avatar
^^ There can be some advantages to put them in folders but also some drawbacks. I have my artists in Alphabetical order (an A folder for artist with last name A, a B folder for the artists who's last name start with B and etc)
Old 06-08-2013 | 12:37 PM
DennisLeo's Avatar
8th Gear
I think the car has a memory setting personally where it remembers the directories of a certain usb device. Therefor I moved files onto it and it did not see the new files. I am trying to recopy everything again as a whole. I will let you know how it goes.
Old 06-08-2013 | 06:18 PM
I_Like_Scotch's Avatar
I put all my music (in folders and subfolders) on USB stick. I only had an issue once where the stereo told my that the stick was unrecognisable. Turns out this particular USB had a built in security software that was messing with the car's stereo. Once I reformatted the stick everything worked fine.
Old 02-22-2019 | 03:41 PM
HondaJockey's Avatar
What formatting did you use to make it recognize the USB? I feel like I've tried everything
Old 02-23-2019 | 06:08 AM
JD8's Avatar
JD8
Standard FAT format is what I used. Though I have had a hard time getting it to recognize some flash drives. Large capacity, USB 3.0, and the small monolithic drives seem to be problematic.
Old 03-22-2019 | 11:04 AM
brenakie's Avatar
Registered RDX Member
Question Search Folders?
I use folders too. Is there any way to search?? I've looked and don't think there is, I'm pretty sure it's just scroll and scroll.....
Had to ask...
RLX-Sport Hybrid
3G RLX (2013+)
43
12-16-2015 10:45 PM
ibGTV
09-28-2015 03:40 AM
SilverJ
1/2G MDX (2001-2013)
09-21-2015 02:40 PM
HeloDown
09-08-2015 06:51 PM
Quick Reply: Usb Flash Drive Folders
