Transmission Issue?
Old Nov 25, 2021 | 07:02 PM
Sox34's Avatar
Transmission Issue?
Today, my 2017 RDX Advance starting shuttering and making a disturbing noise when shifting at low speeds when accelerating from a stop and when accelerating from a slow speed. Any thoughts on what this could be? It has 41,000 miles, is in great shape and is dealer maintained.
Old Nov 26, 2021 | 09:00 PM
Alex Medeiros's Avatar
alexmed2002
Does it sound like a louch screech each time the tires rotate, similiar to the issue I was having as linked below?
Old Nov 27, 2021 | 12:17 PM
altair47's Avatar
Check the transmission fluid level because you are serviced by a dealer and that is bad.
Old Dec 2, 2021 | 06:14 AM
Enhale's Avatar
If the tranny shifts really hard and there is a loud bang...Oil Pressure Switches - one or more are going bad
Old Dec 2, 2021 | 07:59 AM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
https://youtu.be/AEcuvzf_Ahs
Yours sounds like a backer plate or dust shield. If you have them, I would put the front end up on jack stands with the transmission in neutral and see if you can spin the wheels by hand and recreate the noise. If need be, do the same with the rear. Doing so you should be able to isolate the noise from the transmission and subsequently at each corner.
Old Dec 2, 2021 | 08:02 AM
NBP04TL4ME's Avatar
I agree with this. 41,000 miles is fairly low, have you had any transmission or rear differential fluid (you don't mention if you are FWD or AWD) maintenance done?
Old Dec 3, 2021 | 11:34 AM
alexmed2002
I ended up having a seized driver rear caliper that wore down so much so, to the point where it was metal on metal. I got that replaced along with warped rotors and my car feels brand new lmao.
I also agree. 41k miles is like just breaking in the car.
wnally
3G RDX Problems & Fixes
256
Jan 5, 2022 10:48 AM
DvM
Apr 25, 2018 06:08 PM
tfs1975
1G RDX Problems & Fixes
Jun 29, 2012 02:18 PM
josner
Jun 8, 2009 03:41 PM
ravemother
1G RDX (2007-2012)
Oct 20, 2006 11:03 PM
