Tire Sensors
Old Dec 9, 2019 | 10:18 AM
Poolman's Avatar
Tire Sensors
Had a side wall blow out in the RDX over the weekend. The spare doesn't have the tire sensor and when driving down the road one tire of course was at 0 pressure and the others showed correct pressure. Later all pressure monitors were out and have stayed that way, Question, once the bad tire is fixed , will the pressure monitors be back to normal, or is there a fix I must make happen ?
Old Dec 9, 2019 | 11:19 AM
dave08902's Avatar
Hello Poolman,
The other tire sensors should not go out. When you get your tire fixed, the system should reset itself as long as you use the same sensor. If you need to replace the sensor, then you need to re-learn the sensors.
Old Dec 12, 2019 | 11:35 AM
Poolman's Avatar
4 New Toyo's all around and all is well. Sensors are correct again.
KrisKasprzak
Oct 21, 2016 09:32 PM
rocket_pup
Apr 3, 2016 11:56 PM
steve
1/2G MDX (2001-2013)
Feb 6, 2014 10:29 AM
Edubb0118
Jul 12, 2013 01:10 PM
4x4 bandit
1G RDX (2007-2012)
Jun 12, 2007 07:12 AM
