Side Mirrors Adjustment
Every time I shut down the engine both side mirrors go out of adjustment. Thus every time I get into the car I must adjust both mirrors.
This doesn't seem to be normal. Is there any way to fix this issue?
Have you programmed the desired positions into memory?
Have you seen them move when you shut down the engine or just noticed them out of position the next time you get in?
emry (10-15-2016)
The user manual has clear instructions on how to set the mirrors to your desired position. You can also adjust the reverse tilt position to your liking. If these don't work for you then there must be something wrong with the car. Let us know how things are and we will proceed from there. If you don't have access to the user manual at present we can help you from that aspect as well.
emry (10-15-2016)
oracion
1/2G MDX (2001-2013)
05-27-2016 06:00 PM
boss2k
03-12-2016 02:01 AM
Rolex Paws
3G RLX Audio, Bluetooth, Electronics & Navigation
01-31-2016 06:52 PM
