Shut off beep on tail gate ?
Old Oct 27, 2016 | 01:36 PM
R. White's Avatar
After a couple of months, I am find the beep when the tail gate opens and closes to be annoying. Does anyone know how to shut it off ?
Old Oct 27, 2016 | 04:22 PM
rosen39's Avatar
These?
Attached Thumbnails Shut off beep on tail gate ?-unknown.jpeg   Shut off beep on tail gate ?-unknown-1.jpeg
Old Oct 27, 2016 | 04:32 PM
Take apart the tailgate and find the buzzer unit and cover it or remove it altogether
Keyless access and tailgate beep - Acura MDX Forum : Acura MDX SUV Forums
Old Oct 28, 2016 | 11:21 AM
markAZ's Avatar
Open & close it manually. It doesn't beep then. At least mine doesn't...
Old Oct 28, 2016 | 02:10 PM
jcross1231's Avatar
Touring
Mine isn't all that loud.
Old Oct 28, 2016 | 02:23 PM
dirleton's Avatar
It's a warning. Supposed to be annoying. Get over it!
Old Oct 28, 2016 | 05:27 PM
Carman3's Avatar
RDX 2016
I removed the buzzer on mine a week ago. Best thing I have done since I purchased the car.... The buzzer is located on the driver side behind the bumper. Follow the harness and it ends with a pug in for the buzzer. The down side is if you double click to confirm you locked the car there is no buzzer. However the lights blink. Also if you get out of the car with the engine running and have the key in your pocket there in no buzzer to remind you the key is in your pocket.. After I removed the buzzer i used electrical tape over the connector to prevent dirt getting into it and possibly shorting out. When I sell the car I'll put the buzzer back in.
Old Oct 28, 2016 | 09:01 PM
Comfy's Avatar
2014 RDX AWD Tech
I think this is the most reasonable option while at home or in a garage. Use the buttons to close the tailgate only in open and noisy parking lots. At least there the beep gets drowned out.
Old Oct 30, 2016 | 02:03 AM
Colorado Guy AF Ret.'s Avatar
Car Crazy for Sure!
You can program the hatch to open "manually"....no beep. It will still close "auto" with the button. When you engage the latch it unlocks and then just a little effort and the hatch lifts easily. Hmmm...I haven't tried
the button inside the cabin yet. I'm sure it will open it...not sure about the beeper!
Old Nov 2, 2016 | 10:57 AM
kareshi's Avatar
it is supposed to be a warning in case anyone is trying to pass under..
Old Mar 22, 2021 | 11:45 AM
ZJames's Avatar
This was perfect, thank you!!! My 2016 rdx beeper was slightly harder to get to than the mdx in this post. I managed to get a piece of tape over the hole and that obnoxious beep is only half as loud now.
Old Mar 26, 2021 | 10:34 PM
egads's Avatar
On my Odyssey, I just disconnected the buzzer. It's a good idea to wrap the connections on a baggie with a zip tie to keep them clean for reattachment.
Now if anyone knows where I can find a replacement that does a tasteful little ding, preferably mechanical, let me know.
Someone on the Odyclub figured out what colors the wires to that buzzer were and put a switch in the rear quarter panel. But there is a cubby there in the Odyssey.
So far I have left the buzzer on my wife's RDX.
Old Apr 5, 2021 | 06:14 PM
BLEXV6's Avatar
I really don't see why you would want to remove this especially if it removes the warning of leaving with the key and engine running.
Old Apr 13, 2021 | 12:19 AM
egads's Avatar
It is unnecessarily piercing. Or it is to me anyway. I imagine that sounds effect folks differently. I may try muffling it. It is beyond annoying to me when standing right next to it.
Old Apr 14, 2021 | 06:32 PM
Thmanx's Avatar
Originally Posted by egads
It is unnecessarily piercing. Or it is to me anyway. I imagine that sounds effects folks differently. I may try muffling it. It is beyond annoying to me when standing right next to it.
I'm sure it's tested to be a specific dB and frequency range. Prob by the Underwriters-Laboratory or similar governing body. Just like smoke alarms in a house... If you don't notice the damn beep when your battery is out... it's not gonna save your life, same goes for the tailgate.
Either way, removing or deadening the beeper in the tailgate with some electrical tape is a perfect solution.
3.2AM
1G TL Problems & Fixes
Dec 5, 2009 07:49 AM
2000tlwdp
Southeast
May 30, 2009 11:13 PM
JJ4Short
Dating & Relationships
41
Jul 16, 2008 08:25 PM
acmw
1G TL (1996-1998)
Sep 26, 2006 12:26 PM
