Seat Memory Intermittent
The seat memory positions based on which key is used has become intermittent. Works about half the time, balance of time it simple fails to move when opening the door. Pressing the Seat button on the door will cause it to adjust properly. Problem exists with both driver keys 1 and 2.
Worked 100% of the time since new until a couple weeks ago, now for some reason not it works only about half the time.
Are both key fobs close to the car when it doesn't adjust? We have an issue where if my wife last drove the car (so it was set to her settings) and we both are getting in and she has her fob in her purse it won't adjust to my settings if she's close to the driver side door when I open it. If I wait until she's on the passenger side before I open the door, it works OK. One time I had both fobs in my pocket and it adjusted to hers. And hers it #2. She says the car likes her better. Kind of funny, actually, but sometime a little irritating. Anyway, that might be your issue.
Yep ours has done this since we bought it. The funny thing is if my girlfriend is driving(she has key 1) it will fail to adjust for all the time, but if I use her key it always moves the seat up to her spot and I have to hit the #2 door button to get it to my position. We have the same issue with the door handle. Sometimes it opens the lock when you walk up (with either key) and sometimes it refuses to open and you have to hit the button on the key fob. Very frustrating they can't get this right on a premium vehicle.
If you experience the problem primarily in the same location, you might consider EMI as being the cause. On the other hand, the push buttons on the fob transmit a fairly powerful signal, intended to work at larger distances. I have noticed at least a 1/2 KM range over open ground.
Gregg
The proximity feature of the key fob has very limited range because of the weak signal strength. As you know it will only work if you are standing within a few feet of the imaginary "cone" that radiates from the drivers or passenger door, or the rear hatch. This isn't a flaw, but rather a feature so that people can't open your doors when you are in the house, or even if you are on the other side of the car. As a result of the low signal strength it is susceptible to interference from other sources. These sources could include nearby radio transmitters (TV, Radio, Wi-Fi cameras, etc, etc) or the interference could come from electrical motors, arcing wires, etc.
neil0311
5G TLX Problems & Fixes
Nov 6, 2016 10:08 PM
NSX_Lvr
Nov 4, 2016 02:28 PM
donkiboy
Oct 31, 2016 09:03 AM
dookie1
ILX Audio, Bluetooth, Electronics & Navigation
Oct 28, 2016 07:46 AM
