Rust on Brake Rotors
Old Jan 27, 2015 | 12:16 PM
banana13's Avatar
Hi I have a 2014 rdx and It only has around 9000 Kms and I notice that on the rear brake rotor there I rust appearing . Does Warranty cover this, can I get it replaced or removed?
Old Jan 27, 2015 | 12:21 PM
its normal.
Old Jan 27, 2015 | 12:30 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
It's just surface rust and as justn said its normal. When you drive and apply the brake it will be removed.
Old Jan 27, 2015 | 02:44 PM
ceb's Avatar
ceb
Driving in rain will cause surface rust overnight. It is completely normal. Even high humidity can cause it. There is nothing a dealer can do and even replacement rotors will rust virtually as soon as they are installed.
Old Jan 30, 2015 | 04:05 PM
ExcelerateRep's Avatar
Former Sponsor
As others have said here, surface rust is totally normal on rotors. As long as you drive the car once in a while, the pad will clean off the rust and remain operational.
Old Jan 30, 2015 | 09:22 PM
Comfy's Avatar
2014 RDX AWD Tech
My car also has the same visible rust since I bought it. It cleans itself after a short drive. Somehow I notice it more on this car than the others...???
Old Jan 30, 2015 | 09:58 PM
NBP04TL4ME's Avatar
Possibly because of the more open wheel design??
Old Feb 2, 2015 | 10:16 AM
Comfy's Avatar
2014 RDX AWD Tech
That may be a factor; but even independent of that I feel there is more rust in that area in an RDX compared to other cars .
While I was checking this out today I noticed that the rear wheel has only one rotor whereas the front wheel has two rotors! I guess that's how it's supposed to be in RDX.
Old Feb 2, 2015 | 10:19 AM
^? what?
Old Feb 2, 2015 | 10:29 AM
NBP04TL4ME's Avatar
Guessing he possibly means solid vs vented rotor along the circumference?
Old Feb 2, 2015 | 10:30 AM
Comfy's Avatar
2014 RDX AWD Tech
^? what?
I'm sorry if I was not clear enough in what I'm trying to say. I feel the front and rear rotors look different. The front one seems to have two rotors attached side to side but on the rear there is only one rotor. May be its just that the shape is different. I will post some pictures in the evening.
Old Feb 2, 2015 | 10:32 AM
Comfy's Avatar
2014 RDX AWD Tech
That is likely what I am trying to describe. Apologies about the confusion.
Old Feb 2, 2015 | 10:42 AM
^ahhh I see.
if that's the case, the fronts are designed that way to cool as quickly as possible.
Old Feb 2, 2015 | 10:46 AM
NBP04TL4ME's Avatar
^^^^ because the fronts do most of the braking.
Old Feb 2, 2015 | 10:55 AM
it's more likely that the rears are made out of cast iron which is more prone to rusting
while the fronts are made out of some type of alloy
Old Feb 2, 2015 | 04:38 PM
Comfy's Avatar
2014 RDX AWD Tech
This is what I was referring to. The front ventilated rotors (the first two pictures) look like two separate discs welded together by metal struts whereas the rear is just one disc. Notice the rusted look in and around the rotor area. As you guys already know, this in no way affects the safety or performance of the brakes whatsoever.
Attached Thumbnails Rust on Brake Rotors-rdx-front-1.jpg   Rust on Brake Rotors-rdx-front-2.jpg   Rust on Brake Rotors-rdx-rear.jpg
Old Feb 2, 2015 | 04:43 PM
Comfy's Avatar
2014 RDX AWD Tech
Picture of rotor from another car (MB) of similar age and use. The rotors as such look similar but the area in general appear clear of rust.
Old Feb 2, 2015 | 05:58 PM
rosen39's Avatar
The outer edge and inner edge can have surface rust. From those photos, the braking surface is clean and shiny and look fine. If the braking surface had rust and corrosion after using the brakes, then you could have a caliper that was "hung up" and not sliding on it's caliper pins.
Old Feb 2, 2015 | 07:12 PM
hand-filer's Avatar
There's nothing wrong with that. That's pretty much what they look like after about a year of use. Strictly cosmetic.
Jul 16, 2017 07:33 AM
lanechanger
Oct 13, 2015 10:56 AM
polish_pat
Sep 30, 2015 12:22 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
