Rpm surging
Rpm surging
Cruising at 120km/h and 2000 rpm (At highway speed with no load) the rpm will fluctuate 200 rpm. This will last 10-20 seconds. When I push the throttle there is no hesitation (premium fuel) with 120000km on the RDX. Haven’t approached the dealer with my concerns since I’ve had the Rdx there for a P3400(VPS stuck off bank 1) Feb. of this year. This being the only work done outside of maintenance to our vehicle.
My 14 RDX was surging at highway speeds or during general acceleration. Per other post here on the forum I had Rear Differential Fluid, Transfer Case Fluid, and Transmission Fluid changed. Problem went away! Mine needed done around 45k miles.
At 120,000kn, you should have had at least two trans fluid changes by now. If you have the AWD version, then the fluids related to that as well.
Do check out the service bulletins related to your model year (that you did not disclose) up in the stickies.
Here is the second one related to a software update on the transmission:
http://www.urvi.net/forumfiles/SB/B17-018.PDF
My 2015 has done that ever since I have had it. Bought it with 39K and the 30K tranny change under its belt, and I had it done again at 60K. I'm thinking it's VCM, but the only thing I'm certain of is that it's annoying.
These are the two best units:
https://www.svcmcontroller.com
https://www.vcmtuner.com/products/vc...e-vcm-eco-mode
Keep in mind that these folks making and selling these things can lay it on a little thick with their explanations of how and why it is important to do this.
Honda did use some experimental low friction piston rings in some models using this v-6 engine. The VCM in those vehicles were and are a disaster.
The Acuras never used those rings and have much better engine mounts to boot. But it is so much nicer to have all 6 cylinders all the time. If one is going to keep
the car long term, I think I would highly recommend doing what you can to keep all cylinders running.
'17 RDX Tech AWD - WDP
I'm experiencing this same sort of thing.
2017, AWD, 35k miles. Bought it CPO with about 22k on it and don't recall this happening originally. That doesn't mean that it wasn't, just that we didn't notice it. 93 Octane High Detergent gasoline pretty much exclusively (there have been occasions where 93 was used that WASN'T High Detergent).
Rear diff was flushed at roughly 30k along with engine oil and filter, getting ready for the tranny drain and fill as well. Since it only seems to do it when traveling at least 35-40MPH and on either a steady grade or slight incline, my expectation was that this was the fuel management / cylinder deactivation controls at work. Annoying, to say the least.
If a transmission fluid service makes zero difference, then the cylinder deactivation controls are going to get shut down.
Update... Had the transmission fluid drained and refilled twice (drain / fill, drive about 150 miles, second drain / fill). After the first iteration, the issue was probably 99% resolved. After the second iteration, it's completely gone. Car had 41k miles at the time the transmission fluid was changed. Rear Differential fluid had been changed at 30k and the problem started around 33k-35k. So, it's not at all related to the rear diff fluid and seems to be completely tied to the transmission fluid.
For reference, I bought a dozen quarts of Honda ATF off of Amazon for about $100 (eight have now been used) and paid a mechanic $200 to do the two visits for me as I didn't have the time or the space to do the work this time around.
