Picked up new RDX tech (first impressions)
Traded in a 2007 MDX for a 2014 RDX tech today!
Reason: Never used the third row, and looking to downsize.
Enjoy the lighter RDX, easier to steer and accelerate!
Noticed right away that the vents don't blow as hard when I start the car.
Anyone know why?
(It's frickin' cold here!)
Less cargo space compared to MDX isn't a big deal; it's sufficiently sized well.
Roomier entry into front seats, but door is farther away to close (minor)
Will take some time to get used to the new button placements.
Like the rear camera, power tailgate, and Dolby sound!
How do people deal with a salt and stuff sticking to our black cars??! (New black car owner rant!)
Sam
Anyone know why?
Sam
Anyone know why?
Sam
Anyone know why?
Sam
I don't live in the snow belt any longer, but if you have a garage you can use one of these no-rinse products to wash your car in the garage.
Like this...
http://www.autogeek.net/optimum-no-rinse.html
They do work well and I have used it to wash my car in the garage in the winter. Uses almost no water. What I do is get a 1/2 gal garden sprayer and fill that with the water/ONR mixture and use that to spray on the car and let it soak. Then it washes up very easily with a wash mit and dry and you are done.
Oh, and while your car is new I'd consider applying Opti-coat 2.0.
Anyone know why?
Sam
Anyone know why?
Sam
I think the vents don't start blowing hard until the car warms up as it is cold air blowing initially.
On the salt front my poor baby was covered in it and it looked real bad. Gotta go to the touchless car washes.
Get your car opti-coat protected. Then you just need to rinse it off and it looks better than new.
The climate control doesn't blow air until it has reached a temp where it'll do you good. No sense in blowing cold air into a cold car. This also warms the car faster.
What does Opti coat typically cost to have put on? I live in Houston so I am not sure where to start. When I looked around today I found information on forums but those users paid from $800 and up easliy.
You can do it yourself. It is not hard. The product is less than $100. The big cost is in the preparation. For a new car, if you are not super anal, you could put it on the factory finish (after proper cleaning) and have great results. Most people that put it on their car will need to spend some time to clean up the paint, swirl marks, chips etc since you don't want to lock that stuff under the Opti-coat. That is where the cost is. I bought a tube and did my TSX and my wife's Civic and still had over half the product left.
Loved all the great suggestions. Thanks!
I've noticed something peculiar that perhaps some of you can explain. After letting go of the gas pedal and start cruising to a stop or a light, the car engine does a noticeable and abrupt deceleration, kinda like a downshift (but it's an automatic!). Is this normal?
I can see how this helps with the braking. But it's something new and I don't want it to be something wrong too!
Sam
Sam
Above 1,300rpm or so when the gas pedal is not pressed the injectors are off and no gas is burned.
This can't be done under 1,300rpm as the engine will start to stutter so some gas has to be burned to keep things smooth.
Anyone know why?
Sam
Anyone know why?
Sam
rockyboy
Jan 25, 2016 06:00 PM
Barb Jackson
Sep 15, 2015 02:27 PM
