OK to run 2016 RDX on regular?
Old 08-31-2015, 10:34 AM
  #41
Make it #7!
5 Acuras's Avatar
Read the last paragraph: High-Octane Hijinks: Is Premium Fuel Better Than Regular? » AutoGuide.com News
Old 08-31-2015, 11:22 AM
  #42
andysinnh's Avatar
So this is obviously a very subjective conversation - not only for the RDX, but for virtually every other Acura car that has the word "premium" somewhere in the same sentence as "fuel". Personally, I've always run the 93 octane in my Acuras just to be on the safe side (and also because 91 Octane is rarely available here in NH).
But I just ran across a very curious article over on edmunds.com and within the article itself, it has links to a "required" and "recommended" list that apparently Edmunds has created to help guide people to whether they should roll the dice or not on lower octane. Interestingly enough, they list the MDX, RDX and RLX as "required", and the ILX and TL as "recommended". You can decide for yourself, but consider this another voice into the conversation...
Save Money and Stop Buying Premium Gas
andy
Old 08-31-2015, 12:00 PM
  #43
mdfree's Avatar
To clarify it is only for the 2016 year that the RDX is required, 2014-2015 are recommended
Old 08-31-2015, 12:53 PM
  #44
Majofo's Avatar
Received 11,843 Likes on 8,574 Posts
It's recommend for both, not required. The K23 turbo should have been required. It got abysmal gas mileage because it was constantly throwing fuel down the pipe to keep things in check (moreso on reggo). It would have been a brilliant platform if Honda executed properly.
Old 08-31-2015, 07:38 PM
  #45
mdfree's Avatar
^^ I was only referring to what the article stated. Yes Acura says recommended for all
Old 09-04-2015, 04:36 PM
  #46
Acc20yrs's Avatar
89/91
I own two identical RDX's, both tech package. I run 89 on one and 91 on the other. The only difference I have noticed is better mileage on the 91 octane. JM2C
Old 09-17-2015, 04:17 PM
  #47
7th Gear
Acuranfan007's Avatar
You won't have any problems running regular on your RDX. The performance difference is minimal and not noticeable to the casual daily driver. Don't waste your money and don't be scared lol.
Old 09-17-2015, 04:26 PM
  #48
Majofo's Avatar
Old 09-17-2015, 04:29 PM
  #49
Received 8,755 Likes on 6,752 Posts
Don't vaccinate your kids either ... It'll kill them or cause Autism.
Old 09-17-2015, 04:38 PM
  #50
7th Gear
Please vaccinate your children....but putting regular in your RDX will cause no harm.
Old 09-17-2015, 05:52 PM
  #51
rockyboy's Avatar
I'm using 91 octane fuel as per the manual recommendations. It is only about 10% more expensive than regular fuel and is supposed to keep the engine cleaner from what I understand. I'm getting near 600 km on one tank of fuel, city driving.
Old 09-17-2015, 05:56 PM
  #52
Holy shit this has got to be the first time you said something we agree on ...
Old 02-01-2016, 01:32 PM
  #53
raaaaam's Avatar
Has anyone used 87 octane fuel in their RDX and experienced engine issues/repairs? I know there has been lots of discussion on this topic, but wanted to know if any damages have been observed.
After we bought our RDX, the sales person said regular gas is Ok and it has no impact on warranty.
The difference of 91 and 87 octane gas here in Canada is about %25.
Old 02-01-2016, 02:56 PM
  #54
ceb
ceb's Avatar
Received 1,277 Likes on 952 Posts
The differences in the word recommended and required are important here. 91 is recommended and 87 and above is required (unless you in a high altitude location - in which case 85 is like 87 and 89 is like 91).
As long as you don't hear pinging when accelerating, then all is well. If your car does ping, then use the higher octane.
The higher octane in this particular engine will give you more power and may give you better mpgs - note the will and may.
Old 02-01-2016, 10:12 PM
  #55
dirleton's Avatar
"After we bought our RDX, the sales person said regular gas is Ok and it has no impact on warranty."
You believe anything a car salesman has to say about anything? Can I interest you in a bridge?
Old 02-02-2016, 09:37 AM
  #56
012TL-GLM's Avatar
From the Manual 2016 RDX:
Refueling
Use the proper fuel and refueling procedure to ensure the best performance and
safety of your vehicle.
Fuel Information
Use of unleaded gasoline of 91 octane or higher is recommended.
• Acura recommends TOP TIER Detergent Gasoline where available.
• Do NOT use gasoline containing more than 15% ethanol.
• Do NOT use gasoline containing methanol.
• Do NOT use gasoline containing MMT.
We recommend quality gasoline containing detergent additives that help
prevent fuel system and engine deposits. In addition, in order to maintain good
performance, fuel economy, and emissions control, we strongly recommend
the use of gasoline that does NOT contain harmful manganese-based fuel
additives such as MMT, if such gasoline is available
Old 02-02-2016, 10:20 AM
  #57
raaaaam's Avatar
Thanks for your responses.
It seems top-tier gas is also important (based on Acura recommendation). That leaves only a few gas stations, eg Esso 91, Shell 91 and Petro Can 91 here in Canada, not a lot of options.
Old 02-02-2016, 10:29 AM
  #58
TacoBello's Avatar
Received 4,416 Likes on 3,322 Posts
I only stick to PetroCan and Shell, myself.
I've tried filling up with Costco, Safeway and even Esso in the past, and I've noticed that with each of those, I always get worse fuel economy than I do with PetroCan or Shell. You save $0.05-0.08/L with Safeway or Costco, but then you get less miles... so are you really saving?
Old 02-04-2016, 01:53 PM
  #59
hovbuild's Avatar
Dealers scam. Regular ok until you have an engine problem and they ask do you run regular. you say yes and they alway say than that is the problem! I just use regular and lie to them like they lie to us! Problem is looked into and one time actually fixed!
RayNA (11-21-2023)
Old 02-05-2016, 06:39 PM
  #60
Danny Boy's Avatar
This is confirmed on Page 22 of the 2016 RDX Quick Reference Guide - Q&A
Is it possible to use unleaded gasoline with a Pump Octane Number (PON) of 87 or higher on this vehicle?
Unleaded gasoline with a Pump Octane Number (PON) of 91 or higher is recommended. Use of lower octane gasoline can cause occasional metallic
knocking noise in the engine and will result in decreased engine performance. Use of gasoline with a pump octane less than 87 can lead to engine damage.
Old 02-06-2016, 08:34 AM
  #61
weather's Avatar
Received 1,267 Likes on 864 Posts
Everyone....This is a simple conversation.
Read the manual, if you understand the meaning of "recommended" and "required", then that is all you need to know. If you understand the meaning and chose to do otherwise, then that is fine but why do we have to have these discussion all the time.
Old 02-06-2016, 09:35 AM
  #62
dbarnhart's Avatar
Perhaps steering this thread in a different direction:
Perhaps here is a way to have your cake and eat it too:
I use GasBuddy.com to find the lowest gas prices in my area. 91 at a station a mile from my house is lower priced than 87 at the gas station across the street. (Right now there is a $1.36/gallon spread between the lowest and highest priced 91 within 5 miles of my house)
jjgoblue33
11-26-2015 12:39 PM
ThermonMermon
09-22-2015 03:36 PM
EE4Life
09-11-2015 10:13 PM
Quick Reply: OK to run 2016 RDX on regular?
