OEM splash guards
Old Jan 3, 2023 | 08:14 AM
firstRDX's Avatar
OEM splash guards
I was looking for a car project over the holidays and stumbled on the OEM slash guards for my RDX. After I ordered them I kind of had buyers remorse, at $112 I though why did I do that. Once I received them and opened the package I thought these are kind of small, but they were well built and solid as a rock and came with all the mounting hardware. Well that kept me busy for about 1 hour and once mounted I thought, that is not much of a splash guard, a normal person probably wouldn't even notice them.
What they do provide is an almost hermetic seal between the fender, wheel well liner and the lower rocker panel at both the the front and the back. No debris or moisture will be able to migrate up behind the fender and wheel well. In Colorado we don't have a rust problem but in states where you have salt on the roads or gravel and mud these would be a functional addition to the car.
OEMAcuraPatrs.com, p/n : 08P00-TX4-200A
Old Jan 5, 2023 | 11:56 PM
Tech's Avatar
If those are the factory items, then I have the same ones. I live where there is plenty of snow and salt. Of course I also use Krown rustproofing.
When I installed my guards, they wrap around with one edge pressed against the paint of the fender. The last thing I want is grit getting between the two surfaces. So I made a template and cut out some 3M PPF that extends 3/8" past the guards.
Old Apr 12, 2023 | 04:41 PM
TLinGB's Avatar
correct URL is oemacuraparts.com
Looks like your fingers were not as fast as your brain!
Old Apr 12, 2023 | 04:45 PM
TLinGB's Avatar
Do these require drilling holes in metal?
Old Apr 13, 2023 | 10:43 AM
Tech's Avatar
They mount using the existing holes that mount the fender liners in place, 4 screws per side.
Its been a while but I believe the kit includes longer screws.
Old Apr 13, 2023 | 01:27 PM
TLinGB's Avatar
Beautiful. Thanks for the response.
Now I have to go through the guilt and pain that you did. The price has gone up some more (big surprise) for four small pieces of plastic! One place even lists them as out of production for my car.
Old Apr 13, 2023 | 10:31 PM
firstRDX's Avatar
No drilling required. A right angle #2 phillips ratchet driver "YANKEE" makes it easy... that way you don't have to turn the wheels.
Old Apr 14, 2023 | 08:01 AM
Tech's Avatar
You can also turn the wheels fully left or right.
christopher1
ZDX
Apr 3, 2015 07:43 PM
cdavis1
Dec 21, 2011 12:31 PM
steadydaddy
Oct 31, 2003 11:36 AM
SilverBullet_RENAMED
Nov 28, 2002 12:15 PM
