Noise issue with 2013 RDX
The car has been flawless for about three years. Wife drives it each day and barely has 18K miles., Couple weeks ago wife tells me
there is strange noise from the front wheel area/driver side. I drove the car couple days later and indeed, when slowly turning , accelearating
or simply moving steering wheel while standing with foot on park, there is some strange "poping and banging noise" from the front/driver wheel
area.
Took the car to the dealer. Sometime later I got call that sway bar links are the problem and need to be replaced. Fine. Drove the car back home
in the evening and the noise is still there.
Anyone had something similar or has any ideas before call #2 to the dealer ?
area.
If you say "change the shocks" then it won't be covered. If you say "I appreciate you looking at my car and trying to fix it by replacing the sway bar links but that hasn't fixed the problem. Could you look for other issues? Perhaps it could be a defective shock?" then it should be covered.
Struts n shocks.
Read through this entire thread : https://acurazine.com/forums/2g-rdx-...-noise-933591/
New strout took care of the problem.Reading above link, seems as some dealers are fixing noisy strouts ?
I was told I got new one ....that is 1 new one. I would think that strouts being mechanical in nature, would
have to be replaced in pairs to keep things balanced ....??
No more annoying noise.
el1668
Sep 4, 2016 08:34 PM
gbrucken
May 3, 2016 06:22 PM
