Heated seats memory
Heated seats memory
The cold weather is setting in and I want to start making use of the remote engine start on my Advanced RDX.
I noticed that I can leave the HVAC system will start with the engine at the last temperature I left it, however the front heated seats don't.
Is there a way to make the seats also start with the previous settings and turn on when using the remote engine start?
TIA
TIA
I also don't believe that the HVAC system will heat the car to the temperature you left it at. The owners manual says..........
While the engine is running, the vehicle will automatically precondition inside the vehicle.
When it is warm outside:
• The air conditioning is activated in recirculation mode.
When it is cold outside:
• The defroster is activated at a moderately warm temperature.
• The rear defogger and door mirror heaters are activated.
I have tried that and it doesn't work. The seat heaters and blowers (if equipped) default to off when starting the engine. They are electronic switches that send a pulse each time they are pushed. They do not have four unique settings for High,Medium, Low, and Off, and therefore cannot be left in any particular setting.
But I must say, the RDX remote start has a much longer range....
Our new Honda RL has a system where the heated seats and heated steering wheel are activated with the remote start, when it is cold outside. It is a nice feature that I just used on a snowy day when leaving the office. Unfortunately, it doesn't look like our RDX's do the same thing (not that we have the heated steering wheel here in the US, anyway...): just defroster, rear defogger, and door mirror heaters...no seat...
The almost exclusive reasons to have a remote starter is to heat, cool, defrost, etc the car before you get there.
It could be something as simple as better software or mechanical switches.
In my 2013 MDX if you leave them on when you turn off the engine, they will be on when you start the car the next time. It's a no brainer!
It is really mind blowing how Acura drops the ball with details like this.
My seat heater switches are the same as yours.
My wife's RDX is Advanced and it has 3 level heating and 3 level venting buttons. The level adjustments are electronic by pressing the buttons, not mechanical positions like on my MDX.
Anicra
4G TL Problems & Fixes
09-19-2016 05:00 PM
tenaciousg77
07-12-2016 03:58 PM
