Could someone post a pic of their RDX base console?
Old Nov 15, 2014 | 08:45 PM
FredRupert's Avatar
Hi Folks,
I'm considering buying an RDX.
I want to see what the screen looks like for the rear view camera.
All the pics I see are for the RDX tech.
TIA
Old Nov 16, 2014 | 02:38 PM
BLEXV6's Avatar
Originally Posted by FredRupert
Hi Folks,
TIA
I have the Tech, but have driven the non-tech. The screen is about 1/2 the size for the back-up camera compared to the Tech version, not to mention a very simplistic audio display also the same smaller size. This feature alone justifies for me the Tech version.
Old Nov 16, 2014 | 04:04 PM
skywalker168's Avatar
here. found online.
Old Nov 16, 2014 | 08:41 PM
Comfy's Avatar
2014 RDX AWD Tech
If rear view camera is important to you then you should lean more towards the tech version. The large and clear view improves the confidence while reversing.
Old Nov 17, 2014 | 10:21 AM
Scheffy's Avatar
I have the base and have no issues seeing what's on the display when backing up. I can easily get the rear bumper to within an inch of whatever is behind me, provided the lens is relatively clean. Keep in mind that there are wide-view and top-down modes you can select for different view angles as well.
Old Nov 18, 2014 | 09:17 AM
FredRupert's Avatar
Thanks everyone for the pics.
And cool! I didn't know about the modes.
Honestly I turn around to look most of the time when backing up.
I like to use the camera first to check for pedestrians, etc though.
Old Nov 19, 2014 | 10:50 PM
Comfy's Avatar
2014 RDX AWD Tech
I'm sure that the base RDX camera is just fine. All I wanted to say is that the screen is a bit bigger and I like that as it increases the image resolution.
Yes the three viewing modes are an awesome feature of Acura. I mostly use the wide view and usually you can see up to 180 degrees rearwards. It is very useful when backing out from a driveway / parking spot when your direct view is blocked by other vehicles / objects.
Old Nov 29, 2014 | 10:04 AM
Gidds91's Avatar
Here are two from my 2015 RDX Base
Old Nov 29, 2014 | 10:21 PM
Comfy's Avatar
2014 RDX AWD Tech
Thanks. Just curious. What does the bottom part of the screen show? I mean the separate display at the bottom of screen.
Old Dec 2, 2014 | 07:49 AM
AC set temperature. One number each side for driver and passenger.
Old Dec 11, 2014 | 10:00 PM
Gidds91's Avatar
Yes indeed. Good layout easy to use.
Old Dec 20, 2014 | 01:25 AM
panamera125's Avatar
I like how this new generation still looks complete without navi. The 07-12 models had that huge black display and big empty panels on the bottom that looked like they were missing something.
Feb 25, 2020 09:57 AM
rseb4agze
May 3, 2016 07:41 AM
bymotion
Nov 18, 2015 11:28 AM
ThermonMermon
Sep 22, 2015 03:36 PM
