2nd Gen RDX TSB's
2nd Gen RDX TSB's
TSB's:
Follow these instructions.
1. Open this 1. Open this link .
2. Select any entry to fill in the information for make, year, and model, then click on "submit vehicle information".
3. Open any of the listings.
4. You can now open the below listed links.
Many thanks to TSXV6Guy for sharing this method with us.
2012:
TSB 12-008: 2013 Acura Paint Codes
TSB 12-009: (2013 RDX) 2013 RDX TQI and Service Information
TSB 12-010: (2013 RDX) 2013 RDX TQI of Navigation System
TSB 12-025: (2013 RDX) Rear Seat Doesn't Fold Down
TSB 12-026: (2013 RDX) Front Floor Undercover Rattles at Highway Speeds
2013:
TSB 13-004: Siri Eyes Free HFL Software Update (2013RDX)
TSB 13-015: MIL Comes On With DTC P3400 and/or P3497 (2013 RDX)
TSB 13-017: 2014 RDX: TQI Information
TSB 13-018: 2014 RDX: TQI of the Navigation System
TSB 13-019: Safety Recall: 2013 RDX Shift Interlock Stopper
TSB 13-020: 2013 RDX: Front Brakes Squeal
TSB 13-029: Front Doors Do Not Unlock or Open in Freezing Weather (2013 RDX)
TSB 13-030: HFL (HFT) System Issues (2013 ILX, 2013 RDX, 2014 ILX, 2014 RDX)
TSB 13-040: Tailgate Spoiler Seal Comes Off (2013-2014 RDX)
2012:
2013:
TSB's:
1. Open this link .
2012:
TSB 12-025: (2013 RDX) Front Floor Undercover Rattles at Highway Speeds
1. Open this link .
2012:
I thought maybe on My Acura.com..and if you are signed up with your Acura(s) you might be able to access TSB's, but, I tried and that didn't work either.
So...what's the answer??
Thanks.
When trying to open "link" it says that I am not authorized. Which is normally the case. I have found, in the past, Honda TSX links that were put on line by Honda techs....but, when discovered Honda "closed them."
Thanks.
Thanks.
If you looking for installation or DIY instructions for a purchased accessory, you can find it here
Use that link.
After selecting your vehicle and you get to the list of the instructions for the available accessories then you should be able to access the TSB's.
Example:
http://techinfo.honda.com/Rjanisis/pubs/SB/B12-026.PDF
Edit: Make sure your security settings in your browser are not set too high. It has to be able to accept a cookie when you get to the accessory instructions download page. That cookie is what gives you permission to go directly to the TSB links.
mwadden (04-28-2013)
this works.
Once you get in using the above method you can change the last few digits in the address and find other pdf files as well. "B12-034" is also relevant to the RDX. The HFL has an update to address the crappy voice tag recognition, iphone and android issues, and random disconnect/re-connect issues and some sms issues.
http://techinfo.honda.com/Rjanisis/pubs/SB/B12-034.PDF
I checked every number up to 50 and didn't find anything else '13 RDX related.
Just had the Siri Update put in my car - pushes the HFL Firmware to 1.08 (1.05 is factory and 1.06 is the update mentioned above). Anyway Siri works amazing and the iPhone 5 works flawlessly now! I'd recommend anyone who has a 2013 RDX to request this update be performed! TSB # 13-004
http://techinfo.honda.com/Rjanisis/pubs/SB/B13-004.PDF
NutznBoltz (02-03-2013)
New TSB released - this happened to my RDX when it had 3,000 miles - turned off car and turned back on and it never happened again. Dealer could not replicate the issue. Nice to know that there's a fix now.
http://techinfo.honda.com/Rjanisis/pubs/SB/B13-015.PDF
Here's more TSBs
Recall for safety lock of the Gear Shifter.
http://techinfo.honda.com/Rjanisis/pubs/SB/B13-019.PDF
Brake Squealing - FINALLY they've acknowledged this
http://techinfo.honda.com/Rjanisis/pubs/SB/B13-020.PDF
thephantom (03-11-2014)
http://techinfo.honda.com/Rjanisis/pubs/SB/B13-020.PDF[/QUOTE]
are the dealerships supposed to replace this for free?
Anyone still have access to those? I could use a copy of the brake squeal TSB. I mentioned the problem last time I was at the dealer a month or so ago and they said there's not much that can be done. Now I find out there's been a TSB on it for a year...
SidhuSaaB
05-30-2020 12:40 AM
