2018 Acura RDX Technical Service Bulletins
Forum Contributor
Received 1,391 Likes
2018 Acura RDX Technical Service Bulletins:
TSB 17-024 - 2018 RDX: TQI Information
Applies To: 2018 RDX - 2WD
2018 RDX - 2WD with AcuraWatch Plus Package
2018 RDX - 2WD with Technology Package
2018 RDX - 2WD with Technology and AcuraWatch Plus Packages
2018 RDX - 2WD with Advance Package
2018 RDX - AWD
2018 RDX - AWD with AcuraWatch Plus Package
2018 RDX - AWD with Technology Package
2018 RDX - AWD with Technology and AcuraWatch Plus Packages
2018 RDX - AWD with Advance Package
http://www.urvi.net/forumfiles/SB/B17-024.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-024.PDF
TSB 17-025 - 2018 RDX: TQI of the Navigation System
Applies To: 2018 RDX - All with Navigation
http://www.urvi.net/forumfiles/SB/B17-025.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-025.PDF
TSB 14-025 - Timing Belt Chirps
Applies To: 2016-18 RDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B14-025.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-025.PDF
TSB 17-049 - Brake Judder (2013–18 RDX)
This bulletin is replaced by S/B 19-009, Front Brake Noise and/or Front Brake Judder.
This bulletin replaces S/B 16-002, Front Brake Noise and/or Front Brake Judder (2013-16 RDX).
http://www.urvi.net/forumfiles/SB/B17-049.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-049.PDF
TSB 18-008 - Navigation Showing Inaccurate Location
Applies To: 2017-18 RDX - ALL with navigation - ALL
http://www.urvi.net/forumfiles/SB/B18-008.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-008.PDF
TSB 19-009 - Front Brake Noise and/or Front Brake Judder
This bulletin replaces S/B 17-016, Front Brake Noise (2016-17 RDX), and S/B 17-049, Brake Judder (2013–18 RDX).
Applies To: 2013-18 RDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B19-009.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-009.PDF
TSB 19-059 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram
Applies To: 2007-18 RDX
http://www.urvi.net/forumfiles/SB/B19-059.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-059.PDF
TSB 20-038 - Steering Wheel Rattles
http://www.urvi.net/forumfiles/SB/B20-038.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-038.PDF
TSB 23-029 - Warranty Extension: 2017-18 RDX 6AT Torque Converter – DTC P0741 Stored
Applies To: 2017-18 RDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B23-029.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-029.PDF
TSB 23-035 - MIL Comes on with DTC P0441
Applies To: 2018 RDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B23-035.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-035.PDF
TSB 23-038 - Safety Recall: Multi-Model Acura Fuel Pump Motor Stop Sale
Applies To: 2014 RDX (AWD) - Tech - Check the iN VIN status for eligibility
2018 RDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B23-038.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-038.PDF
http://techinfo.honda.com/rjanisis/p.../B23-038v4.PDF (Link works, but is wrong) Version 4
2018 RDX - AWD
dave08902 (11-09-2019)
