2017 RDX Nightmare
2017 RDX Nightmare
We purchased a 2017 RDX in July 2016. Less than 2 weeks after we bought it, brakes started squeaking- after some inspection, they replaced the rotors and pads. Now we are at just less than 18 months, and 2 MORE SETS of ROTORS, and 4 more sets of pads, and the brakes still squeak and sometimes it still jerks a bit when you begin to stop. Acura/Honda knows this is an issue... the dealership basically wiped their hands clean. The manufacturer basically doesn't care. Anyone else have these issues...? I read somewhere there was a class action suit about this... Thoughts..?
Squeezing brakes, while very annoying, don't necessarily indicate there is any kind of issue. It could just be the pad material the RDX uses, combined with the environmental conditions in which the car is in (humidity, etc). What you could do is get an after market set of pads- I suggest looking on tirerack and going with an all ceramic pad. It should cure the noise issue. Metal based pads tend to squeak more than ceramic. Not sure what the RDX pads are made of, but if they are metal based, that could very well be it.
2016 RDX Base AWD had this but lived through it
2016 ILX Premium had this only when car wasn't used for a period of time, lived through it
2018 RDX AWD Advance just picked up yesterday and squealed for a moment. Point being big deal, no reasons change your breaks or rotors. If this is such an annoyance change brands?
a one post wonder?
If only the OP had suggested a class action suit in the first sentence I wouldn't have had to read any further. These guys seem to pop up in forums for all manufacturers, suggest the same, get shouted down and are never heard from again. OP, if you're still around, just go to the auto supply store, get some 'disk brake quiet' (or similar) and apply it to the offending pads. A simple solution.
Cheers!
Cheers!
Could it be this TSB?
https://acurazine.com/forums/second-...letins-942331/
TSB 17-049 - Front Brake Noise and/or Front Brake Judder (2013–18 RDX)
I think a lot of people who spend $40k on a vehicle expect certain things, because, well they just dropped forty large.
I look at it this way; cars are made of metal, there ARE going to be squeaks and squeals, etc. and should only be a minor annoyance
Every brand has some kind of issue I'd rather had it be squeaky brakes than a faulty transmission
