2016 RDX "Setup" Button
Old 09-24-2015, 03:43 PM
dirleton's Avatar
Need some help and, yes, I have read the manual. I'm playing with things on the new car I picked up yesterday, for instance compass calibration and zone. The manual reads "Press and hold the SETUP button until the display shows the compass setting menu." So --- where is this setup button? There is a "settings" button but pressing and holding that just gets you a sore finger. What am I missing? Please help.
Old 09-24-2015, 04:13 PM
Desert Ridge's Avatar
Car must be running, in neutral.
Old 09-24-2015, 04:27 PM
dirleton's Avatar
That doesn't work. Just wastes gas and still get sore finger.
Old 09-24-2015, 04:48 PM
I Driver 1 key inside the car? (and, Driver 2 key away from the car?)
"Settings" button should bring up a menu on the nav screen that can be engaged from the whiz wheel.
Old 09-24-2015, 04:53 PM
giovane's Avatar
It's only for base version. On 2016 models with nav, there's no calibration. The nav should know where you are and adjust the magnetic declination zone by itself.
Old 09-24-2015, 05:04 PM
rockyboy's Avatar
Did you try going into the Nav menu then pressing settings? My compass didn't need any setup... if I press the "i" button on my steering wheel it will cycle to a compass also.
Old 09-24-2015, 06:57 PM
RDX-Rick's Avatar
Old 09-25-2015, 12:25 AM
dirleton's Avatar
It would make sense that the GPS nav makes it so no fiddling is required and therefore no provision is made for said fiddling. Seems they should include a disclaimer however, like they do about clock setting.
jjgoblue33
11-26-2015 12:39 PM
govtcheez
10-01-2015 12:21 AM
rockyboy
09-27-2015 11:08 AM
rockyboy
09-17-2015 03:50 PM
dlevesque
09-16-2015 10:18 AM
Quick Reply: 2016 RDX "Setup" Button
