2016 RDX Full Size Spare Tire and the Foam
I just purchased at 2016 RDX. It has a full size spare tire. In the compartment around the spare is foam like you would get in a box with a new TV with some molded compartments for the tire changing tools. Any issues that you can think of with removing the foam, putting the tools in a bag and gaining more space for more tools and such? The only thing I can think of is noise may increase.
Thanks in advance....
Thanks! I wasn't looking forward to spending $400 for a donut tire. I will have 2 sets of tires and rims (summer and winter) and it's good to know I can use one of those as a spare. Just need to buy the car now.
If you see my pic above, You can see trap door has a place to rest around all edges and center has the black supports on tire. I think its just for sound, not structure. I might take out foam take out insulation the compartment with a different material and .
Spottydog (11-28-2015)
Yeah you are right about temp tire that is smaller. Its not classics doughnut either, but it'd measured at 165/90R17. You might be able to get a legit spare (235/60R18) in the compartment if you shave some of the black foam on the trap door. It will be awfully close.
So the RDX has two different sizes of spare tires? That's interesting.
@OP. Can you post the measurement seen on your spare tire please.
ps. I see that you'd already posted it in the previous post. Thanks.
If I understand the metrics, 165 (165/90R16) would be the width of the tire in mm. If that's right, the 165 doughnut would be 6.5" wide and a 235 would be 9.25" wide.
I haven't purchased my RDX yet, so I can't go out and measure the depth of the compartment. I would be much obliged if one of the RDX aces on this forum could check it out for me.
OK, I just heard back from a dealer who measured the spare tire compartment. She advises that a full size tire/rim will NOT fit in the compartment. I'll probably check it out myself in deference to dirleton's dead-on comment.
The full-size tire is not going to fit in there.
