Won't up shift
Won't up shift
My transmission has been acting strange intermittently for the last two weeks.
Today I thought it failed for sure, I started out at moderate speed, in d-5.
I kept accelerating and the transmission wouldn't shift. The tack quickly went to 7000 rpm so I backed off the gas, and it shifted to second gear. A few miles later it seemed to wanted to stay in second gear.
The car only has 25,000 miles. Fluid is full and red.
Anyone else had this problem ?
Originally Posted by mrsteve
Did the tach go to 7,000 without the car accelerating?
What speed were you traveling? The car won't go into 2nd gear unless you are below 55-60mph.
The dealer checked the car, and said the transmission has failed.They ordered a replacement transmission.
Sad for a car with less than 25,000 miles.
They indicate the replacement solves the problem. I'll see.
Originally Posted by MisterMehoff
mine does that sometimes. do you think i should have it checked out?
It sure wouldn't hurt to getyour car checked.
I was afraid that the car wouldn't shift at all as it got worse.
SidhuSaaB
05-30-2020 12:40 AM
Hines57
09-24-2015 01:58 PM
