Question on tranny failures.
Old Jul 31, 2003 | 12:14 PM
Edward'TLS's Avatar
6G TLX-S
Page 522
Clutch Q/A while Shifting
Table with temp rise and other stats for WOT second-to-third, WOT third-to-second (kick-down), and closed throttle 5-to-3 MANUAL downshift.
ON WOT 2-to-3 upshift, the delta T was 100 degrees (assume C)
ON WOT 3-to-2 downshift, the delta T was 23 degrees
ON Closed throttle 5-to-3 manual downshift, the delta T was 111 degrees.
“* Clutch Q/A is not too high and is judged to be at acceptable level.”
Can someone explain what the heck is "closed throttle 5-to-3 manual downshift" ? I thought the auto box will downshift from 5-4-3 by itself when the SS is tapped back twice manually.
Old Jul 31, 2003 | 01:47 PM
[DWI]'s Avatar
A 5 to 3 manual downshift is when the driver tells the transmission to downshift from 5th to 3rd by SS and tapping back twice, as opposed to letting the computer handle the shift automatically, the closed throttle part means your foot is off the gas and the butterfly valve is closed, basically engine braking in third gear.
TypeS860
Jan 10, 2026 11:11 AM
Pham Alvan
May 18, 2021 06:48 AM
Pham Alvan
Mar 16, 2016 09:17 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
