Normal Tranny behavior???
Old Feb 14, 2003 | 10:57 AM
kbc5960's Avatar
Hey guys - I wanted to get some details from your experiences.
I have an 01 CL (automatic of course). I have occasionally noticed harsh down shifting. This seems to occur if I have been cruising around 60-80 in 5th gear and then press the gas pedal so that is shifts to 3rd. It will pause a second while the engine revs up, then BAM - catches 3rd gear.
This probably happens 1 out of every 5 downshifts.
Also, if I drive in SS mode, I can reproduce it pretty easily. Drive in 4th or 5th, let off the gas to slow down a bit, down shift to 2nd or 3rd (respectively), then immediately step on the gas when the car starts to initiate the down shift. BAM - the car catches gear.
It does this probably 3 out of 5 times.
One last occurance (and this occurs every time), is when I am comming to a stop. Instead of reaching a complete stop, I'll step on the gas to accelerate right before the car stops. The car seems to be in the middle of it's down shift to 1st gear - BAM the car catches 1st and lurches foward. There is no smooth transition.
Is this normal - or should I just not drive like that? Actually I don't really drive like that in SS mode - it's just easier to reproduce the harsh down shifts that way. I would think the transmission should be able to smoothly react to these things. I have had no other transmission problems, but the harsh downshifting seems to be increasing in frequency.
I have noticed with various cars that some automatic transmissions just work better than others. For example - most Dodge cars I have driven experience some of the behavior I described above. They are also notorious for failing.
What are your experiences? Have any of you guys notice the behavior in your CLs? I current have around 38k miles on the car.
Old Feb 14, 2003 | 11:31 AM
dbox's Avatar
whoXwanXsum
i have the same mileage as you and my car acts just as you describe. im on tranny #2 since 20k and im sure this one wont last to much longer...
oh well i hear the NEW tranny is just fine, so let em blow up.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
thegipper
Sep 28, 2015 01:01 PM
