Dilemma about Tranny
I haven't had any problems with my original tranny so far, but I'm wondering if I should do something to get it replaced before the extended warranty expires.
All the bad tranny talk has got me all paranoid.
What would you guys do? Either keep the original and hope it doesn't go bad after the warranty OR do whatever it takes to get a dealer to replace it hoping I get a good "fixed" tranny that won't have the problems everyone is talking about with the original trannys.
Acura/dealer won't do anything until you are stranded on the side of the road .. when it happens make sure you put up your "Thanks Acura" sign in the rear window for all to see....
By do "anything", I mean "anything". There's always something that can be done to make something not work, right?
I just don't know if I'll end up better or worse off if I replace a tranny that didn't have a problem to begin with to avoid a potential $5K repair out of my own pocket when the extended warranty expires.
It's funny, but I can't help think of George W. as I'm writing this. It's like a pre-emptive strike!
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
So when Acura released the numbers on the failures there were 1.2 million possible cars affected, and the number they released was 2% failure rate.
Let's make this scenerio worse... let's use that same 1.2 million (I know... it's higher now.. but work with me). Ok, so we'll use that same 1.2 million number, but instead we'll say the failure rate was 5%. If you do the math you'll see that it effects 60,000 cars out of 1.2 MILLION. And that's all cars affected... so it includes the Odessey, Accord, CL, and TL. I think that's it... basically any car with the 5 speed auto tranny. When you actually think about it... the numbers are clearly on your side.
Don't be so paranoid.... just enjoy the car. The odds are that you will not have any problems. The odds are also that if you did happen to have a problem after 100k, Acura would take care of you. But no dealer is going to replace a good tranny... especially when that tranny could be 1 of 1,140,000 trannies that will never have a problem.
As for DivinDude's comment.... sounds to me like your dealer sucks. My dealer replaced my tranny after the first sign of slippage.... they didn't wait for anything worse to happen.
Originally posted by mrsteve
OMG a thousand miles later?????? or did u have 44.8k on the 2nd tranny?
Biggie_B
02-26-2017 11:14 AM
