View Poll Results: Your damper setting for daily commute (if front & back different, please indicate)
.000 Softest
0%
.125
0%
.500
0%
.625
0%
.750
0%
.875
0%
Voters: 4. You may not vote on this poll
Yellow Koni - Damper setting for daily commute (poll).
Manny Tranny
My current setup is CT Springs and Sways and I am about to put Yellow Koni’s on. I am leaning toward softest setting to smooth out the ride.
I don’t want to be too soft and give up tight handling and I don’t want to be so tight that I feel every bump.
Where have you guys settled (dampers) for every day commuting?
Koni yellow - Damper setting for daily commute
I wish I could help you. I have Koni yellows but I have no idea how to change the damper setting using numbers for the various settings as you have shown in your example. Can anyone tell me how to do this?
Where is my super sauce?
I have it set about 1/3 at all corners. I tried at 1/2 and thought it was too stiff for daily commute, and likewise set at like 1/4 and thought it could still be tightened up a tad.
Manny Tranny
Manny Tranny
If you have the Yellow Koni Sport, you should see this. Just turn the knob. There are no numbers, i was just using numbers to get an idea how far you guys are turning the knob.
Is there a difference between Koni Yellow and Koni Yellow Sport? Are they the same thing?
I found Koni Yellow on a website, and I'm wondering if it has that damper setting knob.
Manny Tranny
3.2 CL, Adj. spring perch can lower car approx. F & R=20mm 01-03 8041-1257 Sport (Front) 8041-1258 Sport (Rear)
Koni Yellow - Damper setting for daily commute
They say that one picture is worth a thousand words, and now that you have posted a pic, I have a clearer idea of what you were inquiring. I have the H & R sport springs with a 1.75" drop in the front and 1.50" drop in the rear with Comptech sway bars installed. I have a full turn all round on the Koni's and do not find that setup to be at all uncomfortable on the highway. As a matter of fact I plan to increase the rear damping one half turn for an even stiffer ride.
Boomer SOONER
why are the Koni Yellows nearly twice as much as the Tokico Illuminas? I am about to get a new shock/spring setup and I was leaning toward the Tein H Tech springs and Illumina shocks. I would almost rather have a slight raked look because of my system. I really hate it when the back is lower than the front
CheeseyPoofs McNut
10-11-2015 11:25 AM
09-17-2015 09:01 PM
braveheart
09-07-2015 08:12 AM
