Would these fit????
Old 06-10-2009, 03:00 PM
Mac424's Avatar
Would these fit????
would these wheels fit our cars and what do you think about them??
http://www.elites-wholesale.com/Shop...id/0/SFV/32431
Old 06-10-2009, 07:20 PM
3.5 psi
gnuts's Avatar
Wheels look pretty nice. Not sure what that bolt pattern is. I know it should be 5x114.5
You should confirm on that.
Old 06-10-2009, 11:43 PM
nf3d0149ab's Avatar
Won't fit...like gnuts said...not the right bolt pattern.
Old 06-11-2009, 12:12 AM
Mac424's Avatar
i didn't think they would but the web site has a screwed up bolt pattern system and i'm not sure any of the wheels the show when you put in the car model would fit
just thought i would ask because the price was right and i need some rims bad!
Old 06-11-2009, 03:15 AM
nf3d0149ab's Avatar
Ever look for used?
Craigslist or the Black Market here on Acurazine?
Old 06-11-2009, 08:00 AM
Is a chargin mah lazar in
Onese1f's Avatar
I just took a look at that site and it doesn't look like any of the selections under "18 inch wheels" have the right bolt pattern..
Old 06-11-2009, 03:17 PM
Mac424's Avatar
i just found another site that said the cl"s bolt pattern was 5x4.5
Old 06-11-2009, 03:33 PM
LIST/RAMEN/WING MAHSTA 짱
princelybug's Avatar
Close! But the actual bolt pattern is 5x144.3!
Old 06-11-2009, 04:00 PM
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,445 Likes on 3,043 Posts
try another site
Old 06-12-2009, 02:49 AM
Mac424's Avatar
ok 1 last question, for an 18x7.5 wheel would a 53 or a 45 offset be better
thanks a lot guys really appreciate all the help
Old 06-12-2009, 02:54 AM
nf3d0149ab's Avatar
+45 is the stock offset.
So that would be better.
Old 06-12-2009, 03:00 AM
Mac424's Avatar
i thought so but wasnt sure im looking at a set of enkeis that have the 5x114.3 bolt pattern and has both offsets. enkeis website recommends the 53
Old 06-12-2009, 03:03 AM
nf3d0149ab's Avatar
Nah...go with +45 if you have a choice.
Old 06-19-2009, 08:04 PM
I ♡ PEK PEK
n0rm's Avatar
5 x 114.3 is the same as 5 x 4.5, 114.3 mm = 4.5 in.
Old 06-19-2009, 08:50 PM
nf3d0149ab's Avatar
I have to correct myself...
Stock offset is +55 according to the FAQ's.
Old 06-19-2009, 10:32 PM
Mac424's Avatar
so the wheels would fit?
Old 06-19-2009, 10:40 PM
nf3d0149ab's Avatar
Yeah the offset would be fine.
You could fit much lower offset...but would require fender modification.
Anything +40 to +55 would be just fine.
The offset can also help to determine the size of the wheel's lip.
The lower you go...the wider the wheels.
That might not be the right terminology but that's how I understand it.
Old 06-19-2009, 10:47 PM
nf3d0149ab's Avatar
You can be a little flexible on the offset.
But offset in relation to wheel width is where you can run into some fitment issues.
Really wide wheels with low offsets are going to be much harder to fit...
And will require either fender modification (pull, rolled, shaving) stretching tires, running more camber or a combo. of all three.
Does that help?
Old 06-20-2009, 12:14 AM
Mac424's Avatar
yeah thanks i knew the offset range but i didnt really understand it.
now that the fitment issue is cleared what do you guys think of the wheels as far as style, price, and how they would look on the car
Old 06-20-2009, 12:21 AM
nf3d0149ab's Avatar
If it's the right bolt pattern (5x114.3) they'll fit no problem.
But according to the site, those particular wheels are a different bolt pattern.
The style of the wheel I like but not the black face.
Not a fan of black rims...
Old 06-20-2009, 11:11 AM
I ♡ PEK PEK
n0rm's Avatar
See post #14 above regarding bolt pattern.
Old 06-20-2009, 11:44 AM
nf3d0149ab's Avatar
Old 06-20-2009, 12:03 PM
I ♡ PEK PEK
n0rm's Avatar
LOL, hey I thought "tia" was aunt in English.
Old 06-20-2009, 12:08 PM
nf3d0149ab's Avatar
So we're even...lol
Old 06-20-2009, 12:39 PM
monkeybutt's Avatar
These wheels will definitely fit/bolt up to the car, but your next pertinent concern depends on what size tires you intend on running. 235/40/18 will preserve your speedo accuracy, but w/ a 42offset you are gonna rub in the back. I run this size tire w/ on 18x7.5 48 offset and even then had to roll the fender lip. You could run 225/40/18 w/ your choice and probably not rub, but I could easily discern the higher revs needed for a given speed when running the smaller tire.
Old 06-22-2009, 09:36 PM
Mac424's Avatar
out of these two which do you like better im getting ready to make the purchase and was just wondering your opinions
or
not much different but still can't make up my mind
Old 06-22-2009, 10:13 PM
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,221 Likes on 4,853 Posts
I like the first one.
Old 06-22-2009, 10:29 PM
nf3d0149ab's Avatar
No. 1 > No. 2
Old 07-04-2009, 12:35 PM
JoeyBello's Avatar
Hi I am posting here since I cannot post new topics yet.. I found a guy selling 2005 TL rims for cheap and was wondering if anyone has them on their CL or a pic of them on a CL - preferably red so I can get an idea how they look.. if so email it to me please..or the link.. Italibello@aol.com thanks!
emailnatec
29
09-28-2018 04:27 PM
vpasla1
09-17-2016 07:24 PM
ROWDY621
09-30-2015 03:20 PM
xsilverhawkx
09-28-2015 06:51 PM
Bielikb96
09-28-2015 10:45 AM
Quick Reply: Would these fit????
