Will 19x8.5 +30F / 19.9.5 +40R fit on 03 CLS
I think I'm about to pull the trigger on the EuroTek U03 and I wanted to make sure they will fit on my car. What tire size will I have to run and what fender mods will I have to do to make them fit? I am currently on stock height and will be buying coilovers as well at the same time. Looking for entry level coilovers ($600-$700 dollar range), but willing to spend a bit more if its worth it and will benefit me when it comes to fitting my rims (if coilovers include tophats with camber adjustments). Any help would be greatly appreciated. Thanks!
http://www.mrrwheels.com/uo3.html
19 x 8.5 +30 F
19 x 9.5 +40 R
19 x 8.5 +30 F
19 x 9.5 +40 R
not sure about the clearance from the strut tower to the wheel. those offsets are high for a wide(r) wheel. usually the wider the wheel the lower the offset you want, its odd that the 8.5 wheel has a lower offset than the wider. you may need to run spacers.
right now im on 19x9 +24, fenders are rolled and slight pull and running camber. youll want to stretch your tires a little as well if you want to have a nice stance
im on 19x9 +24, my fronts stick out 17mm past his, and my rears are 10mm past his and although i do run camber, my wheels dont stick out past the fenders.
so after he gets his suspension and alignment right, he may want spacers if he wants, depending on what look hes going after
emailnatec
29
09-28-2018 04:27 PM
