wheel spacers
wheel spacers
OK, i was just brosing King Motorsports and i came across H&R wheel spacers. I read a little bit about them and they say not only do they give you that european kinda widebody look but also improve handling by stabling the car more. I'm just kinda curious as too what you guys think about this. Theyre pretty cheap too only 75 a pair.
Former Sponsor
There is no need to run a spacer unless you need one. If you had a BBK and needed clearance then run a spacer. Now the H&R's spacer are complete kits. If you do choose a large enough spacer they include new studs to ensure you have enough of the lug threaded on. Besides if you wanted to do a spacer i would think you want it in the rear but on this car you could easily rub with a spacer pushing the wheel out further in the rear, esp. if you are lowered.
i have 25 mm spacers all around, the car looks definitely 100% meaner, and the rear does not rub with 215 tires with stock suspension. i am dropping my car on hr sports and illuminas next week ill see if rubbing will appear
25mm, that is insane. He had to have changed the studs, I dont think anyone would be that crazy to put a 25mm spacer on our car and not change the studs. How my car looks is important, but no mod is worth doing if it makes your car unsafe, just beacause it looks good.
Former Sponsor
Originally Posted by RaviNJCLs
That's nuts. The fact that it doesn't rub is cool. But with a 25 mm spacer (1 inch), that's a lot less thread for your lug nuts. You are really running the risk that the bolts can come off. I think most of the guys here that use spacers for the BBK, use like a 5 mm spacer, or just enough to gain clearance. If you really need the look, then maybe you should get longer studs just to be safe.
I'm Cool
Well the only reason i run spacer is because of the bbk. Otherwise, i won't even bother with the whole spacer=better handling. What we really need for better handling is wider and more stickery tires
I'm here in spirit...
Originally Posted by Bobbydoedoe
Well the only reason i run spacer is because of the bbk. Otherwise, i won't even bother with the whole spacer=better handling. What we really need for better handling is RWD
Originally Posted by CLSpeedster
so then how would that be dangerous? i cant see a company selling dangerous products to consumers.
They definately won't recommend you use a 25mm spacer on you CL.
thanks for all the input fellas.....
Need 4 Speed...
1 Post
My best friend is a mechanic and I have another friend who has a 2001 Audi S4. It's bright yellow and he bought black rims with the chrome lip around it. Look phat. The rims did not fit but he wanted those rims on the car badly. My mechanic friend told him about spacers but did not recommend them and felt uncomfortabe putting them on. My other friend finally convinced him to do it and a week after it was done, while he was taking a turn at 10 mph getting off an exit ramp, the wheel fell off and damaged the front bumper and front left vender. The wheel just went flat against the ground. It didn't fly off or anything. The car looked like the Delorean in the movie Back to the Future 2 - lol. The rim was all scraped up too. They fought for a week on who should encore the cost but they ended up splitting it. Could have been much worse if he was going faster. Thats my
Originally Posted by Excelerate
I know for sure the 25MM kits come with longer studs. What they do is set up 10 holes. 5 to fit your original studs through and 5 nuts that are torqued down specifically to hold the spacer on. And the other 5 holes get new studs to make sure the wheels have enough threads.
jmoney2001
09-11-2015 12:07 PM
mtl_ilx
09-03-2015 09:48 AM
