tires?
Old Apr 15, 2002 | 06:41 AM
ch1276's Avatar
tires?
what do you guys think is a better fit for tires?
235/40/18 or 225/40/18?
Old Apr 15, 2002 | 07:05 AM
Shawn S's Avatar
I believe the 235 will give you a closer overall diameter, but there is a better chance of RUBBING depending on the RIM width, offset and design of the tire.
I went with the 225 to be safe because I am dropped on Comptech Springs.
Shawn S
Old Apr 15, 2002 | 07:11 AM
Shawn S's Avatar
Stock 17”= 25.47” dia
225/40= 25.08” dia
235/40= 25.40” dia.
Shawn S
Old Apr 15, 2002 | 02:21 PM
DreamU's Avatar
Depends on your rim width and comfort preferences. If your wheel is 8.0" wide the 225 will be recommended by the tire manufacturer, if you are 8.5 wide the 235 will be recommended (per Michelin for example). However, the range for either rim width covers both tire sizes so no problem either way. This is where comfort comes in. Putting a narrower tire may give a firmer ride, putting a wider tire may provide more cushion. However, we are only talking 10mm difference here - probably not noticeable. The difference of 1mph at 75mph if you go with the 225's is also not very much. Its your call. (No rubbing on my 235's)
Old Apr 16, 2002 | 08:37 AM
ch1276's Avatar
ok....so i planned on ordering 18x7.5 rims with a +48 offset, but they can't get them.....does anyone see a problem with 18x8 with a +48 offset on 225/40/18 tires with comptech springs....even if i have other people in the car?
Old Apr 16, 2002 | 09:17 AM
Rod's Avatar
Rod
I would think you'd even be fine with the 235s, but I'm not sure. People with 235/35/19s and Comptechs seem to be fine as long as their offset is 45 or higher.
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
DidiBob
Jan 4, 2016 12:41 PM
Robospinner
22
Sep 24, 2015 08:47 AM
CostcoFanAUS
Sep 18, 2015 06:05 AM
fallacy
Sep 4, 2015 10:15 AM
