Springs for the rake look?
Pimp Daddy Gold
Being part of the "rusted Comptech springs" club, I've decided to change them. I would also like to change the stock shocks to either Tokico hp blues or Bilsteins - coilovers are not an option for me as I don't need the adjustability.
Question is, what springs will give me the rake look that I have with the Comptechs? (if any) I believe the original advertised drop was 1.5" front and 1" rear. I found 2 advertised springs with the same .5" difference - Tanabe Sustec NF210 and TEIN Luxury Master High Tech, both available from autocarparts.com. Does anyone have these springs? What do you guys think?
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
Yeehaw
why not just get new comptechs. the new ones are made by eibach right, so they shouldn't have the rust problem?
btw I have comptech with tokico blue and I have the rake. I hate it though.
Pimp Daddy Gold
Blown is Best
Originally Posted by 1coolcat
Based on the other pics that I saw of the Eibachs, the drop looks even...some have the droopy butt look, in my opinion. The old Comptechs have a more pronounced rake, which I like.
Pimp Daddy Gold
Originally Posted by Allout
Others have made that same comment but I'm not sure if I agree. The old Comptech's had a difference of .25" between the front and rear. The new Comptech's/Eibach's have a .35" difference between the front and rear.
an adult perspective
Eibach (Comptech) springs on Neuspeed/Koni Yellows ... depending on the perches used, you can have droopy butt, level, or rake ... this looks like a rake to me
![](http://img.photobucket.com/albums/v381/Y2K3CL-S/Comptech%20Black%20and%20Neuspeed%20Koni%20Yellows/Driversside.jpg)
![](http://img.photobucket.com/albums/v381/Y2K3CL-S/Comptech%20Black%20and%20Neuspeed%20Koni%20Yellows/Driversside2.jpg)
Pimp Daddy Gold
Originally Posted by mclarenf3387
Just go coil-overs, and adjust it to the hieght you want.
Springs & blings
Question is, what springs will give me the rake look that I have with the Comptechs? (if any) I believe the original advertised drop was 1.5" front and 1" rear. I found 2 advertised springs with the same .5" difference - Tanabe Sustec NF210 and TEIN Luxury Master High Tech, both available from autocarparts.com. Does anyone have these springs? What do you guys think?![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
I've got the shocks set at 3/4 firm so I can corner like a rat in a maize, but you can dial em down if your lady likes a softer ride.
Doin' da crack shuffle
I got the Comptechs and love the rake look. I'll be going with the Tein Luxury Springs probably next summer. My Comptechs are barely rusty yet. I'm sure this winter will kill them though.
Coilovers aren't an option for me cause I already got Koni Yellows.
Where is my super sauce?
I'm in the same boat too.
My Comptechs are just getting rusty but not yet rusted. I do like the Comptech conservative drop and the slight rake.
I just got my Koni Yellows through the group buy.
I think that I'm going to go for the H&R 50103 (yes, the one for the TL, not the one for the Accord). My understanding after some research is that this spring will give a conservative drop that should be slightly raked on the CL.
Depending on what people post regarding the Tein Luxury springs, I may consider going that way. I don't really want to be the guinea pig for these.
One reason to not go for the Tein Coilovers (I've already made a decision to not go this way) is the non-progressive spring winding. Too many people have posted that they'll bottom out with this set up. That would drive me crazy.
I don't wanna be the Guinea pig for the these either but they are Tein Springs. I have yet to hear about something bad that Tein makes.
7-30-05 First Place STS!
I'm in the same boat (no pun intended) as you are.
Originally Posted by azian21485
linear rated springs will be stiffer than progressive springs (and much more predictable)...not sure why they'd be bottoming out...i'm not a fan of hyped tein anyways though =)
The issues raised with the Tein SS coilovers (not saying these are real *problems*, just issues to talk about) are:
1) the springs are not progressively wound
2) the springs are somewhat soft, but upgradable to a firmer (but still non-progressive) set
3) no bumpstops available
4) because of 1, 2, and 3, some people have mentioned bottoming out to be an issue.
bottoming out has very little to do with the spring rates and more to do with the valving of the shocks. If you have higher springrates and your shocks aren't valved to handle the spring rates, then you're going to bottom out. Too soft of dampening is what will cause your shocks to bottom out. Here's a scenerio, if you put koni yellows on stock springs does anyone have problems with bottoming out? stock springs are progressively wound, preloaded, and have low spring rates. The konis (or any shock) won't bottom out because the spring rates aren't really high
progressive rates or linear rates have nothing to do with the shock bottoming out or not
the only difference between progressive rates and linear rates is that a linear rate spring has the same spring rate throughout the entire spring. progressive rates have incremental increases in spring rate throughout the spring. linear springs will have a stiffer ride and progressive springs will offer the smooth ride some people like.
tein is based on racing. That's why they don't use progressive springs
tein's shock vavling is based on the accord which i skimmed is about 150-100 lbs lighter than you guys. One reason why you guys might be bottoming out is the added weight causing the springs to preload more (compress), causing them to "increase" spring rate more and the shocks can't handle it since they were vavled for lower spring rates (another reason i don't like tein).
so upgrading springs (which btw you don't have to go through tein..if you guys wanted to upgrade springs might as well go with better springs from eibach or hypercoils...they offer any rate you guys want and have a large racing history) to higher spring rates isn't the answer. Either go with lower rates or get the teins revalved or shortened or find some bumpstops if you wanna stick with them.
it also depends on how low you guys are but i'm assuming no one here is really slammed or anything
"You my boi blue!"
So do you think I will have any problems with bottoming out if i get the Tein Basics and drop it the same as Old Comptechs (F1.5 and R1.0). That is about low as I would go and since I cant adjust the shocks with the basics, do you think I will have any probs of any kind with the drop that I mentioned above?
i can't tell you if you'll bottom out or not because i have zero experience with teins...but it seems that the reason tein is bottoming out for the cl is that it's just being used on the wrong car..it's all speculation right now though
are the basics for the accord or cl? i'm sure other people who are running basics can chime in on their experience
you MIGHT not have a problem...but don't base your decision on what i say because i have no personal experience...people who run basics should chime in or u can ask around?
MrHeeltoe
20
02-23-2023 01:54 PM
emailnatec
29
09-28-2018 04:27 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
