Rial Nogaro Wheels? Any Info? How come tirerack says these fit? Doesn't add up
1) Anyone ever heard of these wheels? What is the quality, etc?
2) Look at the dimensions, these won't fit will they? How come tirerack says they do? Or do they make dimensions that do fit our cars?
Finish Shown: Bright Satin w/Machined Lip
Size Selected: 19x8
Price: $239 (each)
Recommended Tire Size: 225/40-19
Wheel Offset: 40mm
** Lightweight: 25.4 lbs. **
Additional Specs
Bolt Pattern: 5-114
Finish Warranty: 2 YEARS
Country of Origin: GERMANY
Construction Type: 1 PC CAST LP
![](http://www.tirerack.com/images/wheels/rial/swap/rial_nogaro_bstn_ci3_l.jpg)
Size Selected: 19x8
Price: $239 (each)
Wheel Offset: 40mm
Additional Specs
Bolt Pattern: 5-114
Offset is too low. They will rub. If you get a 19x8 wheel, you should keep the offset above a +45. And if you find one with a +45 offset of higher, you should get 235/35/19's, not 40 series.
Mugen TSX
Eastern Canada
09-01-2015 11:11 PM
