question on +offsets
I Heart 6 Gears.
Im looking into getting some new wheels.. I'm currently lowerd on Eibach pro kit.. now I understand that out offset is at 45.. but what about if i had a wheel that was 18x7.5 +42?? of on the other hand an 18x8 +45? I need to know asap.. help me out boys!
Our stock wheels are 17x7 +55. I will almost guarantee you rub with 18x8 +45 on the pro kit. That's the drop I had (w/ stock shocks) and I rubbed with 17x8 +48 prior to having my fendors rolled. You MAY get away with the 18x7.5 +42. It also matters greatly what width tires you choose (and even brand, as the sidewall slope of the tire is not equal for all kinds despite a similar width).
I believe the stock offset is actually 55. I would say that a 45 will work well for 18's. My Axis Mods are 45's and they fit fine with out any rubbing and they are 19x8 rims. A +42 will be pishing it, but I think you would be OK as long as you're not dropped too low.
I Heart 6 Gears.
how about a 225 tire or a 235?? and ravinj.. what are u lowerd on? the wheels im looking at, the one is 18x8 with +48 and a 235/40/18 tire.. and the other is a 18x7.5 with +42 and a 225/40/18 tire.
Also, if you're in Jersey, stick with 18, and beware of the pothole. Which wheels are you looking at?
Originally Posted by fuzzy02CLS
I'd go with the 18X8 +48 235-40-18 tire ones. Not only will the tire be speedo accurate, but the +48 is a better fit then a +42.
You may rub with the +42. I did & I only had the old CT springs. The pro kit lower more.
I've got 18x8 +42 Momo GTR 2-Piece rims and there are just right. Any more offset and they would stick out too far. The Michelin Pilot Sports have the extra rubber rim guard so it makes it look a little fatter but like I said any more offset and it would stick out too much.
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
